WiiM Sound Lite Speaker Review
Rate this lifestyle speaker:
    Votes: 22 16.5%
    Votes: 69 51.9%
    Votes: 40 30.1%
    Votes: 2 1.5%
It is indeed one channel testing. I made the choice of setting it to "left" which did cause both tweeters to run at the same time, causing that beam forming. Turning one of them off would have then reduced treble energy. Seeing how they have you select Left/Right if you used them as a pair for stereo, I thought my selection made sense.
These are difficult speakers to test and one has to make some kind of choice in testing them. In this case, I found that the on-axis response was subjectively correct even though I was driving the speaker in stereo when music listening.
It is a bit disappointing that both tweeters are playing when the speaker is set on left.
My question was about feeding a stereo signal to a single speaker, which is a use case that would fit many of such lifestyle speakers. In which case the left and the right tweeter should receive decorrelated signals and the comb effect wouldn't be as pronounced. That's the theory anyway, it would be good to have some confirmation.
Hmmm. So you think the natural roll-off of the woofer is around 180Hz and the Wiim added a huge PEQ boost at 80Hz to compensate? Wouldn’t a low shelf have been a better bet?
I’m still not convinced that a 4” woofer designed for LF would roll off that high, though. Something ain’t right.
That's not weird at all. Look at something like the Dayton TCP115 (which is definitely designed for LF) in 1 liter sealed, the box tuning comes to around 110Hz, yielding a very similar roll-off, around 3-4dB down at 100Hz. Yes, a low-shelf would have been better, that's why I'm saying it's a poor design :)
But if RoomFit was on during the measurement, how was it then able to be used to correct what you're saying was already a result of the correction being on?
Frankly, I have my doubts about that... I think we should clarify this with Amir. Here's what was said:
"Once the process was done, I noticed an immediate but subtle improvement with the sound seemingly opening up. Then I looked and the Roomfit calibration was still set to Off!!! In other words, I imagined it. :("
Not a product I would be purchasing but I am always interested by a WiiM product review.
Speaking of which, I am wondering if @amirm has been contacted by WiiM with regards to testing a potential successor to the Ultra??? Any exclusives for us?
Apparently they've just pushed a firmware update to these with Roon support.
I'd say purchase some small (mini) bookshelf spears, hook them up to actually desktop amplifier, which we have many of nowadays, and get better sound, and save money.
I have the regular version with a screen set up in bedroom with a separate CD player hooked up into its 3.5mm port.
While it certainly needs to have its bass boost killed right out of the box, it's a pleasant little speaker for what it is. And with an external mic on Android, roomfit works pretty good.
I see this more like a little arcade racing game. Not designed to be accurate but it sounds fun.
Then take another quick measurement with your Klippel after the Roomfit correction (ON) to see how effective it is?
Klippel is in entirely different place and not movable. If you mean to take it back there, do you mean to run roomfit there? If so, that is not a hospitable space for in-room measurements.
Roomfit was NOT on during measurements. Bass boost was (I am assuming).
The specs for Sound and Sound Lite appear identical except for the display on the Sound. Does this mean they would likely measure the same?
Same sound. The Lite just removes the display and the included remote:
Source
On the plus side, I could see these going for $65 on Woot in a couple years. I'll be in for two at that price.
Thanks I mean running Roomfit with the suggested parameters and enable it.
RoomFit applies the calculated EQ profile directly to the WiiM device.
Then once enabled : run the Klippel test again to see how it affects the speakers
On the other hand, this only makes sense if the listening room is the same one where your Klippel setup is located...
Actually, what I would like to determine is the efficiency of RoomFit.))) Or do you have an idea for determining this point?
That's a huge question.
As RoomFit is merely an automatic Parametric EQ generator, and after calibration you get all the calculated EQ parameters as an editable preset, measuring the difference using the Klippel is really unnecessary.
You can just look at the EQ parameters or the EQ graph and that's 1:1 the difference.
The screenshot below is from a manually created preset, but RoomFit presets are identical in the App:
The PEQ generator is frequently being improved via updates to the WiiM Home App.
It is also configurable in its behavior, and of course the results fully depend on both the room response measurement and on the RoomFit settings.
That makes determining the "efficiency" both complicated and not very useful, as the next software update could invalidate all findings.
Sure. I think his question is 'are those good results?'. Which is a huge question.
The permanent question people have about all RC is, "yes, it looks good but is it really good? "
As if there's some definitive answer (other than the usual, FR, phase, etc) that can reassure them even if things are simple:
A nice 3D scene, nothing to bother, nothing missing or stick out, etc.
