WiiM Sound Lite Speaker Review
Rate this lifestyle speaker:
    Votes: 22 16.5%
    Votes: 69 51.9%
    Votes: 40 30.1%
    Votes: 2 1.5%
This is a review, listening test, EQ and detailed measurements of the WiiM Sound Lite powered lifestyle speaker review. It was sent to me by the company and costs US $229.
The look is as expected in this class which is to say solid. The non-lite version sports a colorful round LCD which can show clock, track information, etc. There is a touch panel on top to adjust levels and skip/rew the track. For the rest, you need the WiiM app which I used to set the volume to max for my testing using AUX analog input.
Speaking of inputs, I appreciate unusual inclusion of Ethernet RJ45 jack. So many are limited to WiFi only. Power supply is thankfully built-in. All the connections are underneath the speaker with a channel to round the cables out.
The actual configuration of the speaker is a 4 inch mono woofer and two tweeters flanking each 45 degree top corner. Speaker can be configured to run mono, stereo or left/Right only. For measurements, I configured the speaker for Left. Listening tests were performed using stereo.
Dual tweeters are there to provide spatial effects despite both being housed in the same box. The challenge with that from measurement point of view is that the two will interfere at higher frequencies creating a very complex soundfield. That complexity requires high sample rate for Klippel NFS to resolve. Not wanting to spend 2 days measuring :), I opted to still use my 1000 point measurement sampling. I was pleasantly surprised that degradation (accuracy loss of higher than 1%) didn't occur until above 10 kHz.
WiiM Ultra Lite Speaker Measurements
As usual we start with our anechoic measurements:
I did not realize that by default there is a volume dependent bass boost until went to listen to the speaker after the measurements. :( Subjective effect is small at high playback level that I used for measurements but it may be responsible for that hump around 80 Hz. If so, I don't know why that was the selected boost, leaving a deep notch above 100 Hz. There is elevated treble response, likely due to summing of both tweeters. Or maybe that is intentional tuning. Directivity is quite uneven due to two tweeters beam forming:
Which naturally causes off-axis response to be uneven:
WiiM Sound Lite Smart Speaker early window Frequency Response Measurements.png
But somehow doesn't sum too badly:
WiiM Sound Lite Smart Speaker predicted in-room Frequency Response Measurements.png
Slope is rather flat though so signature may be bright.
Back to directivity, vertical response as usual requires staying at tweeter axis:
Even at max volume, I could not the WiiM to play at 86 dBSPL so opted for 81 which was -3dB lower:
But you expect that for the class.
Waterfall shows some resonances:
Step response starts a bit strange:
WiiM Sound Lite Listening Tests and EQ
I started listening in stereo mode as mono was kind of unexciting. I immediately noticed some tubbiness which led me to finding out about the bass boost. Its effect was very subtle at higher volumes where I did most of my listening. Still, I turned that off.
While the highs gave out nice spatial effects, the signature was just too bright for me. So I decided to give WiiM Room Fit a try. I used my Samsung S23 Ultra phone for the calibration using all the defaults. Test tones were quite loud and seemingly not impacted by the volume control. Fortunately the process is very quick with some high pitch tones and then a CHIRP sweep. Reported response graphs looked thusly:
On the tiny phone screen, I couldn't figure out what was what. It was later that I realized the standard correction window was from 50 to 500 Hz. Company should really use more differentiated colors as it is hard to tell the four graphs apart. Maybe make the target dashed or something to reduce clutter. Vertical scale should also be 50 dB per CEA-2034 standard. Looks twice as high right now.
Once the process was done, I noticed an immediate but subtle improvement with the sound seemingly opening up. Then I looked and the Roomfit calibration was still set to Off!!! In other words, I imagined it. :(
I turned it on but noticed very little change. Due to limit of 500 Hz, the harsh highs were still with me. And so was some of that tubbiness.
I ran another test with the settings full range. Now the highs became way too muffled with no other improvement. Using a phone microphone is likely a recipe for poor measurements.
I gave up and developed my own simple filters based on anechoic response:
I first dialed in that quick and dirty high shelf which nicely tamed the high frequencies. Yes, I gave up some spatial qualities but it was well worth the trade off.
I then filled in that bass hole which brought some welcome warmth. Note however that room modes impact what one is doing here with anechoic measurements.
Bass quality though was still problematic at the levels I was listening (at or near 100%). So played around with a sharp high pass and that seemed to do the trick.
The above filter can nicely be dialed into the speaker itself with multiple profiles to boot.
With all of this in place, fidelity rose to "audiophile" levels most of the time. This is an unfair standard of course but I don't know how to grade on a curve for this class of speaker. For us audiophiles, every product needs to be able to play loud enough, clean enough and with neutral response.
There is a lot of hardware and especially software here at a very good price to give likes of Sonos a run. The response could have been highly chewed up but it is not. There is a bass hole and some brightness which was easily managed through manual EQ. The automated Roomfit seemed to give it the old college try but in the amount of time I tested it, and with the phone mic, it didn't seem to produce anything likable.
Overall, I am going to recommend the WiiM Sound Lite.
If the reference axis is rotated such that it is pointing at only 1 of the tweeter, would the measured comb effect become lower?
Considering how Klippel is taking 360degree measurements, I'm guessing not. But I'm wondering if it could be a calculation thing. Since if one tweeter is on-axis while the other is off shouldn't the sound from one tweeter dominate over any cancellation effect if the cancelling tweeter is, say, -10dB lower due to being off axis 60 degrees
You mean anechoically or in a room? Either way, it is not how the speaker gets used.
Here is a better look at the driver setup:
Very similar layout to the Sonos Era 100:
Both use a sealed woofer, but the Sonos likely has better directivity control with their acoustic lenses.
Acoustically the Sound Lite is identical to the more expensive WiiM Sound, which just adds a small screen and a remote control.
Personally, I'm not convinced by the advantage of multiple tweeters in one small cabinet. It almost always wrecks the directivity.
With a true Mono design you can add Stereo capability by purchasing a second speaker, but you cannot get rid of the WiiM's poor directivity even if you buy two.
not so bad and I agree its works.... if you are in the WiiM family... but seems like a bit of work to get what you may call a "Room Toy" to be a crowd pleaser.... so, I would want a more generic profile from a stocking stuffer. at least give the Boom with the Tish.
thanks
Thanks for the testing, manufacturer spec's;
Dimensions : 5.8” x 5.8” x 7.6” (146 x 146 x 194 mm).
Weight : 5.5 lbs (2.5 kg).
Audio
Frequency Response : 50 Hz - 20K Hz.
Peak Power : 100 W total.
• 1 x 4” long-throw woofer, 50W
• 2 x full-range tweeters, 2x25W
Crossover Frequency : 2.4 kHz.
Hi-Res : Up to 24-bit/192 kHz, gapless playback.
Room Correction : AI RoomFit™ automatic/assisted tuning.
EQ : Advanced EQ in app (presets + custom); separate EQ settings for Wi-Fi/Ethernet, Bluetooth, and Aux.
I/O, Connectivity, & Control
Wireless Input:
• Wi-Fi 6E (802.11 b/g/n/ax, tri-band: 2.4/5/6 GHz)
• Bluetooth 5.3 (Receiver & Transmitter, supports SBC, AAC)
Wired Input :
• 100 Mbps Ethernet
• 3.5mm Aux input
Control:
Touch Buttons:Play/Pause, Volume Up/Down, Next/Previous Track
WiiM Voice Remote 2 Lite (NOT included) : One‑tap playback/volume/skip, push‑to‑talk voice, preset buttons
Voice:Works with Alexa or Google Assistant via compatible devices
App: : WiiM Home App for iOS/Android/Windows/MAC/Apple TV/Google TV
Streaming & Smart Features
Supported Platforms:
WiiM Home App, Chromecast Audio, Spotify Connect, TIDAL Connect, DLNA, LMS, Roon Ready
Multi-Room Audio:
WiiM, Google Cast, and Alexa multi-room systems
Stereo Pairing:
Enables left/right speaker setup for expanded soundstage
Home Theater Integration:
Functions as the surround or center channel speaker in a Dolby 5.1 setup
Smart Preset:
Streamlines the listening experience by offering quick access to frequently used content and settings.
Alarm Clock:
Set the alarm time, occurrence, and choose from various music sources.
Power & Build
AC-powered: 100-240V AC universal power supply; energy‑efficient standby; firmware over‑the‑air (OTA) updates.
Finishes : Minimalist modern, Black/White, Fabric/Glass/PC.
Package Contents
• WiiM Sound Lite Smart Speaker *1
• CA/Aux Cable *1
• Quick Start Guide *1
(No 1.8″ display and no Voice Remote included in Lite.)
JSmith
The standard Klippel test uses mono chirp signals I think. I wonder if those comb filtering effects would be attenuated with stereo signal ie. music where the left and right tweeter wouldn't get the same signal.
I'm pretty easy to please and I'm sure I could get it set up to sound fine for me, but this looks like a rare miss from the Wiim crew. $230 for one speaker that can't get to 86dB? Pass.
Funny timing—I just ordered one last night for my son's 18th birthday. He's looking at colleges far from home, so a compact, all-in-one speaker seemed more practical than my usual choice of studio monitors for the kids. Thanks for the review, Amir; the EQ suggestions should come in handy.
For me, they just don't play loud enough. And it's not a matter of wanting to play everything at a baseline of 81+db, it's that it will clip at peaks even when playing stuff in the low to mid 70's. That's just not an audiophile product. Would be great to see them come out with something larger. With their engineering talent, they can certainly do better.
Thanks for the nice review, Amir.
I initially thought I could use them as wireless surround speakers. But the dual tweeter design turned me off. But as a standalone wiim system, a true all-in-one, I think it is a very nice deal.
Funny the reaction some speakers get here. Seems like some with better measurements have been panned relentlessly. Personally, I have no experience with, nor affinity for, this brand and voted accordingly.
I think speakers like this are supposed to be more like omni or at least 180, so I don't know if looking too closely at the directivity plot the way you'd normally do makes sense. The in-room power curve looks basically fine for the category, but for $229 I am not sure I'd jump on this. If it goes on sale for Black Friday or whatever, you might catch me eyeing it as a "spare room" kind of speaker, since the rest of my house is already wired up for WiiM.
It is indeed one channel testing. I made the choice of setting it to "left" which did cause both tweeters to run at the same time, causing that beam forming. Turning one of them off would have then reduced treble energy. Seeing how they have you select Left/Right if you used them as a pair for stereo, I thought my selection made sense.
These are difficult speakers to test and one has to make some kind of choice in testing them. In this case, I found that the on-axis response was subjectively correct even though I was driving the speaker in stereo when music listening.
If you compare this to the previously reviewed Google Nest Audio, it seems like Google's engineering is definitely superior for this form factor. However, I'd still probably go with the Wiim just for the software, and because eff Google.
Regarding smartphone mic for room calibration, an iPhone might be better. I've read over the years about how accurate and consistent the mics are on iPhones compared to Android competitors
One would think that the software would ask you which phone you have and apply some kind of correction based on measurements of its mic. Otherwise, there is no way to properly do what they say.
I have not read but I assume they accept an external mic for calibration as well? Or is it just the phone?
Afaik Apple gives developers microphone access through their API which includes mic compensation/calibration (though @Greg Wilding can definitely say more about it).
On Android OTOH, every manufacturer is free to do what they want, so microphone response is a wild west.
You can connect a UMIK or other USB microphone to the phone/tablet and WiiM Home will use it for measurements, including the calibration file.
