Emiyanez
Great post!
You're slowly getting there! My two cents... I think that the gain on the sub is still too high so you are over-correcting the signal while you could still lower the sub volume. Ideally, your RAW curve (grey) should overlap as much as possible with the target (green) before you apply the room correction. As @harkpabst suggested, it should be slightly above it in the bass region cause this will help with the correction.
SBIR may be tricky to correct. I also suffer from it in my room with my speakers and speaker placement did not solve it. In your case, frequency is low enough that you can partially compensate by crossing at a higher frequency and applying some EQ. As suggested, try to place the sub centered between the speakers so it's harder for your brain to locate it.
I am not sure about the size of your room but sometimes bigger is not better. It's true that small subs (8 inches) do not have the authority and dynamics of the bigger ones. However, big subs could be an overkill and harder to integrate in certain small rooms.
