What is expected exactly? Are we talking about Roon Ready? Q4...2022?Tech Specs
Software
- Chromecast Audio
- AirPlay 2
- DLNA
- (Roon expected in Q4)
Software
- Chromecast Audio
- AirPlay 2
- DLNA
I suspect 24/192 is Wiim's unofficial extension to Chromecast. Applications following Google's documentation would not try to stream more than 24/96, but Wiim doesn't refuse to play 24/192 if it is sent.Whatever. But the fact remains that the WiiM Pro supports Chromecast up to 24/192 as confirmed by WiiM and my use of the BubbleUPNP and Hi-Fi Cast Apps.
Not my streaming service app, I use Amazon Music which doesn’t support Chromecast for its lossless hd/uhd tracks but doesn’t need to as the WiiM supports AlexaCast up to 24/192.Just not when you use your streaming service app
Google must have put in the limitation to limit wifi issues or heat issues with the chromecast.I suspect 24/192 is Wiim's unofficial extension to Chromecast. Applications following Google's documentation would not try to stream more than 24/96, but Wiim doesn't refuse to play 24/192 if it is sent.
Looks like WiiM aren’t the only ones when it comes to devices with chromecast “built in” as I linked to above https://stereo-magazine.com/review/chromecast-audio-reviewI suspect 24/192 is Wiim's unofficial extension to Chromecast. Applications following Google's documentation would not try to stream more than 24/96, but Wiim doesn't refuse to play 24/192 if it is sent.
So arguably more a limit for the actual chrome cast audio devices than the chrome cast audio protocol?Google must have put in the limitation to limit wifi issues or heat issues with the chromecast.
With Roon you can send to chromecast up to 24/192It is a limitation of the Chromecast protocol. It maxes out at 24/96. Maybe you can use DLNA from Qobuz. It should pop up in the list of available devices.
And with the WiiM Pro, as I have already posted, you can use the BubbleUPNP or Hi-fi Cast apps to Chromecast 24/192 to it. Plus Qobuz can do 24/192 to certain “Chromecast built-in” devices.With Roon you can send to chromecast up to 24/192
Wiim mini already does it, so there's no reason that Wiim pro doesn'tCurious to know if the unit will feed the analog input at the digital output? I have a Yamaha WXC-50 that does this and it's helpful if I want to convert an analog format (like tape) to digital.
I wonder who that user SneakyDS was going on about Amazon MusicDarko did a follow up video
Can you confirm if the 10-band EQ in the WiiM Pro applies to any input you select? I’m specifically interested in knowing if it works for the optical in signal. I assume it does, but if you could confirm I would really appreciate it!It’s expected to go on sale around 10th December - as a beta test user, I got a unit early.
I’d imagine the EQ is applied to the output so is independent of the input.Can you confirm if the 10-band EQ in the WiiM Pro applies to any input you select? I’m specifically interested in knowing if it works for the optical in signal. I assume it does, but if you could confirm I would really appreciate it!
You will get more than you expect if Pro shares FW with Mini actually...Can you confirm if the 10-band EQ in the WiiM Pro applies to any input you select? I’m specifically interested in knowing if it works for the optical in signal. I assume it does, but if you could confirm I would really appreciate it!
