WiiM Pro - Review & Measurements (Streamer)
That is for creating the filter parameters as part of the measurement process.
But once the filters are set up, they have to be implemented/calculated by DSP while the music is playing. This is where the grunt is needed in the MiniDSP.
You’re saying the WiiM continues to change EQ settings ‘live’ while music is playing?
No. The EQ settings stay the same. The processing power is needed to do the calculations involved in doing the filtering. Assuming the filters are implemented using IIR biquads (quite likely - they're a common, versatile building block) then each biquad requires five multiplications and four additions per sample. Generally a shallow filter will need one biquad, while steeper filters cascade two or more biquads. More filters, or steeper filters, means more biquads so more calculations per sample.
Would that processing have to be present for any implementation of PEQ, irrespective of whether it's for room correction or other uses?
penny drop - thank you
Is the problem with eq fixed? Or do we still have to reduce the volume to 95% to be able to use the eq without considerable degradation in the sound quality as mentioned in the OP.
Where in the OP do you see this? I've scanned the OP several times and I can't seem to find where this issue is noted.
Also, why is it a big deal to reduce the volume to prevent what I presume is digital clipping? When utilizing EQ with any amount of boosting you generally need some negative gain to prevent digital clipping, it's not unusual. It would be nice if the Wiim's EQ interface had a field to enter a set amount of negative gain.
PEQ is a form of DSP (Digital Signal Processing).
You can't have Digital Signal Processing without processing....
I think maybe I’ve not explained myself clearly.
Yes, I know that EQ is processing.
What I’m trying to say is if the Mini already has PEQ, and the measurements for room correction are done in the phone, then that negates the previous reasons given for the Mini to be more powerful.
It’s the PEQ that needs the grunt (as others have explained it) and the Mini has that already.
Even if not boosting some negative gain is advisable as phase shift can still cause clipping. It's a feature of DSP, but it's not important unless you run out of gain.
I may be misremembering but I thought the mini got stuck at 4 PEQs while the rest got more, much like the Mini not being able to handle Squeezelite while the others can. The argument then is whether the room correction can be done with just 4 PEQs rather than the full set.
A firmware update brought the mini up to 10 band PEQ. It's quite a remarkable little thing
So, in short, given that this PEQ capability was already on the Mini, and in relation to my original post (in reply to @Overseas ) I was (for once) correct.
no..mini didn't have before the peq 10bands of the other wiims... had been announced as impossible on mini in 2022...
and therefore no rc mode that uses it after testing and calculation...
no..mini didn't have beforr the peq 10bands of the other wiims... had been announced as impossible on mini in 2022...
Except ... the WiiM mini now does have 10 band PEQ (per channel) and room correction ... with no hardware change
Turns out that it wasn't impossible after all.
Any digital effect of any kind requires processing. Whether that is PEQ, graphic EQ, reverb, compressors, etc and so on - even digital volume control. All of them require calculations to be done on each sample.
"Obviously, you do not want to use EQ at fixed volume, unless 57dB SINAD (before D/A conversion) is something you are looking for... It becomes way cleaner with volume is unlocked, the lowered at about 95%. This issue could be easily fixed by firmware, by setting max volume about 1dBFS down."
This is from the OP.
Since then some changes have happened in the app. You no longer need to unlock the fixed volume to lower it. You can do that in the volume limit and keep the fixed volume on.
So I am just wondering if I still need to do that or is the issue fixed. Or I only need to lower the volume when I apply positive gain in the EQ.
