YesBut, but... does it work now for Android and not only for Iphone?
How do they get around the mic calibration issue? Or is that with an external mic?
Give it a try and see how much they differ. My results were pretty similar using my android phone and tablet compared to partner's iPhone 14(?) and iPad.Yeap, it works.
Of course, based on the phone mic.
It displays the corrected curves, all that.
So... if I use some old cheap Iphone do I get much more accurate results than using Android?
Do you have a usb mic you can use with REW?Well, I would have to buy an Iphone so not yet
External mic with Wiim!?I find I get pretty different results with my two Android phones. One is enjoyable, one is boomy and unusable. Next step is to experiment with an external mic. Any suggestions for an affordable compatible mic? Cheaper than the Umik ideally.
www.audiosciencereview.com
Sure you can. I use my Anthem mic.![]()
Could use some 101 advice
Hello, First of all I‘d like to say I’m super impressed with the wealth of exact information and knowledge available here. I had a homestudio once but started traveling about five years ago and haven’t done anything with recording music since. It is now that I’ve temporarily settled in a place...www.audiosciencereview.com
Not sure if you can use it with the WiiM Home App though.
Look on the Wiim forum. Lots of discussion. Umik works, IMM-6 hit and miss depending on model and phoneI find I get pretty different results with my two Android phones. One is enjoyable, one is boomy and unusable. Next step is to experiment with an external mic. Any suggestions for an affordable compatible mic? Cheaper than the Umik ideally.
You do know that you have to remove the phone from the prottective casing, right? ( I'm just kidding)I find I get pretty different results with my two Android phones. One is enjoyable, one is boomy and unusable. Next step is to experiment with an external mic. Any suggestions for an affordable compatible mic? Cheaper than the Umik ideally.
My fault, I forgot to switch the eq off before running the testMaybe they don't. I get strange eq correction, quite different from the one REW with umik suggest me
People are having better results with USB mics.So Umik1 to connect to Android by USB?
If that's the case and you engage the saved " auto" and measure again then that should result in a rather flat response, right?My fault, I forgot to switch the eq off before running the test
