A sort of. Just a scale where reduction from 100% to 1% means 60 dB signal level attenuation.So that % is a sort-of subjective number?
This guy here is a totally subjectivist and he says Yes: 2/10 for sound quality for the Pro And 6/10 for sound quality of the Pro Plus:I know it measures better but is the DAC in the Pro Plus audibly better than the DAC in the Pro? I have a Pro and use the analogue output so I wondered if upgrading to the Pro Plus I would hear an improvement?
This with audibility. Then it will go from theory to practice.All noise and distortion is added in the audio chain.Quoting ocinn:This guy here is a totally subjectivist and he says Yes: 2/10 for sound quality for the Pro And 6/10 for sound quality of the Pro Plus:
But, I think, the hearable differences are quite extremely small:
The Pro has about 90 dB SINAD and the Pro Plus has 113 dB SINAD.
The absolute Threshold of listening is about 115 dB or 116 dB. The physic and human biology just says, that more is simply not necessaire.
But if you play real music this big measurable differences between 90 dB (Pro) and 113 dB (Pro Plus) seems to be barely hearable.
Also you have to ask yourself the question if your amp has more than 90 dB SINAD, which is not likely the case….
Quote: Darko says the EUR 800,— Chord Mojo 2 separate DAC will further increase the sound quality (from 6.0 to 7.5)
But this is definitely not a good advice: SINAD of the analog out of the WiiM Pro Plus is 113, SINAD of the Chord Mojo 2 is 110 dB - which is per se fantastic. But who wants to decrease the sound Quality by 3 dB by adding a separate DAC?
audiosciencereview.com
How often do you listen to pure 1 kHz sine waves?But, I think, the hearable differences are quite extremely small:
Anyone want to arrange a blind test between the two?This guy here is a totally subjectivist and he says Yes: 2/10 for sound quality for the Pro And 6/10 for sound quality of the Pro Plus:
Here's a tip, if you want to test at a slightly lower level:Anyone want to arrange a blind test between the two?
dailyHow often do you listen to pure 1 kHz sine waves?
Should we believe any subjective result not supported by a double-blind level-matched test?This guy here is a totally subjectivist and he says Yes: 2/10 for sound quality for the Pro And 6/10 for sound quality of the Pro Plus:
Only to make it easier to hear distortion.How often do you listen to pure 1 kHz sine waves?
If that fully meets your music taste then yes, sinad can be the one and only measurement although still under some circumstances. Most people rather prefer more complex sound instead.daily![]()
It seems like you might prefer Red Herring.If that fully meets your music taste then yes, sinad can be the one and only measurement although still under some circumstances. Most people rather prefer more complex sound instead.
Oh it was from Amir’s testing: USD 799,—Should we believe any subjective result not supported by a double-blind level-matched test?
The Mojo 2 is ~£400 in the UK. Where does €800 come from?
www.audiosciencereview.com
I might try an as-new used one, but not ~£400 for a nice toy. Richer Sounds has it for £395 <https://www.richersounds.com/chord-electronics-mojo-2-black.html> if you fancy a new one.Oh it was from Amir’s testing: USD 799,—
I thought it would be in Europe EUR 800,—
It seems to be a nice toy to play around:
CHORD Mojo 2 Review (Portable DAC & HP Amp)
This is a review and detailed measurements of the CHORD Mojo 2 portable, battery operated stereo DAC and headphone amplifier. It is on kind loan from a member and costs US $799. The Mojo 2 is solidly built. While I am definitely not a fan of multi-color interface, the buttons feel better in...www.audiosciencereview.com
OK - so those percentages aren't voltage output percentages. Must be some Wiim internal representation of volume.See @onlyoneme post above.
I'd be very surprised if anyone can hear that difference with real music in real listening conditions.The Pro has about 90 dB SINAD and the Pro Plus has 113 dB SINAD.
Correct, but I did say I wasn't talking about voltage reductions.OK - so those percentages aren't voltage output percentages. Must be some Wiim internal representation of volume.
Because a 10% voltage reduction is only 0.92dB
A 50% voltage reduction is 6dB.
A 10% power reduction is only 0.46dB
A 50% power reduction is only 3dB
Agreed. In theory the higher SINAD is nice to have. In practice, you'd most likely never hear the difference at home with speakers.I'd be very surprised if anyone can hear that difference with real music in real listening conditions.
Scoring them 2 or 6 (presumably out of 10) is pure audiophile bunkum.
