Have had no problem with this .Thanks, read some reviews on Amazon, quite a number of these fail after short while
also, does it need to be power supplied? I would really hate to add even more devices that can fail...
looks well made but 70 euro on Amazon in EU... I might be better off getting a DAC, so I then also have the DAC besides the conversionI use this one, 6 months now:
Convertor audio digital SPDIF & TosLink bidirectional, Lindy L70411
Converteste bidirectional semnalele SPDIF digitale optice sau coaxiale Suporta audio digital de pana la 24 de biti / 192 kHz Suporta audio LPCM, Dolby Digital si DTS, de la 2 la 5.1 canale Design minimalist, compact si functionalitate perfecta Convertorul si repetorul Lindy SPDIF permite utiliconectica.ro
thanks, I don't doubt it, they probably work well in most cases, I'm slightly concerned with these, as there are a lot of them on Amazon, they all look more or less the same (and probably are, just with different sub-brands), but they all have quite a number of scary stories about failures.Have had no problem with this .
It's $19. And returnable. With overwhelmingly positive reviews. $19.thanks, I don't doubt it, they probably work well in most cases, I'm slightly concerned with these, as there are a lot of them on Amazon, they all look more or less the same (and probably are, just with different sub-brands), but they all have quite a number of scary stories about failures.
Probably still a good choice to start with, together with the Pro Plus, then if becomes an urge, I may get a DAC anyway![]()
you forget I'm in EU, so the one you mention is not a valid option (it would cost me far more in delivery, and import tax than the item itself...).It's $19. And returnable. With overwhelmingly positive reviews. $19.
If you can't hear any additional hiss, none.Would there be any degradation in running the line out voltage to 0.5vrms? Connecting it to my preamp and I don't get good attenuation on it unless I run 0.5vrms
www.nytimes.com
Ultra has HDMI in and Subwoofer management ... if you don't need those and you are not using the WiiM's DAC (or ADC/line in) then you are just as well with the more basic WiiM Pro. Nice problem to haveDebating between getting another Wiim Pro Plus for main system or go for Ultra but will lose Airplay which works great for Apple Music. Will be connected to receiver via coax input.
I did this for a long time, but now that there’s a WiiM tvOS app, if I want to see album art I put it on the TV.In case it’s helpful to anyone: I was torn between the Ultra and the Pro Plus because I like having album art displayed but my wife likes AirPlay. I solved this with an ancient iPad that is nearly useless but runs the Wiim app very stably. It’s on a little easel on an end table and shows whatever is playing on the Pro Plus 24/7, with a display size that is of course much more visible than that of the Ultra. I think it’s a pretty elegant setup solution.
The WiiM Pro Plus with another brand of amp does not support Subwoofer integration since there's only two DAC channels.I just bought a KEF T2 Subwoofer to run with a Sonos Connect:Amp (14 yrs old!) I was counting on a the Sonos' ability to change the subwoofer volume because the KEF has fixed gain- no adjustable knob. But I learned after connecting the KEF that the Sonos Amp only allows subwoofer volume adjustments with the Sonos Subwoofers, not with third party subwoofers. My frustration level is Sonos has gotten to the point that I think I'm ready to replace the Amps. I'm looking for advice on using the WiiM Pro Amp vs. using a WiiM Pro Plus with another brand of amp. The WiiM Pro Amp seems like a nice package but perhaps there are power amps that are substantially better than the WiiM Pro Amp for $600-ish per zone or less? In most rooms, I am driving a pair of B+W 8-inch ceiling speakers.
Ah OK, I see the Ultra has a sub out connector. So same question there, would an Ultra + a non WiiM power amp perform better in a similar cost per channel than a WiiM amp pro?The WiiM Pro Plus with another brand of amp does not support Subwoofer integration since there's only two DAC channels.
The WiiM Amp Pro OTOH has three DAC channels with a myriad of sub integration features.
In Germany, the Ultra costs 330€ and the Amp Pro 400€.Ah OK, I see the Ultra has a sub out connector. So same question there, would an Ultra + a non WiiM power amp perform better in a similar cost per channel than a WiiM amp pro?
Not until you need/want more power.Ah OK, I see the Ultra has a sub out connector. So same question there, would an Ultra + a non WiiM power amp perform better in a similar cost per channel than a WiiM amp pro?
