To me the by far most important part of your system are the speakers, next the room has a big impact. Depending on this combination decent room correction like DiracLive can make a big difference. I recently recommended a KEF Q Concerto Meta + Pioneer VSX-LX505 to a friend as entry level system. I know the Pioneer measures mediocre and has this strange power restrictions issue in Amir's 2 tests (which doesn't seem to happen so often in praxis, I know 3 happy owners), but it has fullbandwidth DiracLive build in.Thank you Randolf. Yes, so much experience on this forum, as a beginner to the digital, not easy to keep up bit by bit I will succed, just when I learned to walk
So today, if going from scratch as a beginner,
would you still begin with a WiiM Ultra + an AMP and then go from there ?
Or will I run into future complications with the WiiM when adding DSP and DAC's ?
Although it seems more complicated, I wonder if I should go straight to a DSP DAC's with DIRAC ?
I know some people here say that WiiM is so great but then I add two subs, and if later on I want DIRAC, it seems to be the wrong way to start ? but perhaps I am mistaken ?
Or am I as Keith here told me, perhaps overthinking ?
Regarding subs I have zero experience. To me it felt never necessary to add one, probably because I very much prefer a little bit less and tide controlled bass and i am no so much interested in super deep bass. But of course if you listen Hip-Hop on a KEF LS 50 Meta things are probably very different
If you want to decide upfront if DiracLive is a big improvement in your setup you can get a 14 day free trial license for your PC. So you may start with the Speakers allone and some arbitrary Amp you can eventually borrow somewhere and test it. All you need is an UMIK-1 mic. If DiracLive doesn't make a big difference for you you can go for a setup without it an save some money. Or if you can get a Pioneer VSX-LX505 with return policy just try it and if it's DiracLive doesn't make a difference for you return it (this way you do not even need a UMIK-1).
