thomasward00
- Joined
- May 13, 2021
- Messages
- 102
- Likes
- 57
At $99 bucks, I don't expect much from the internal DAC and honestly, we shouldn't. I have a good ESS in my Arcam Amp and 2 Schiit Modi 3+'s for my 2 Cambridge Amps.769m
You're worrying about something that's at least an order of magnitude too small to possibly hear.that s just 50% more jitter than the small cca ..2015... not expensive too
possibility of progress with a new firmware?
As for the real musical samples, for me, the effect is different with each of the tracks... For the "Schubert Strings" track, I notice a slight "nervousness" with the sound of the high frequencies and a "grittiness" starting at 875ns which progressively gets obvious. I found detecting the anomaly more difficult with the "Piano Improvisation" sample on my headphones (a bit more reverb to the track masks the distortion). What I did notice by 1750ns was a gradual deterioration of the piano decay with a "hardness" to the sound and this became very noticeable of course by 17500ns and 35000ns where the "dysphonic" fuzziness exerted themselves strongly!
I hope we get there. And someone here can test and confirm true lossless AMHD up to 24/192. Being able to get this capability while casting from the AMHD native app would be a SUPER SIZED bonus... it's light years better than the Wiim Home app.The statement "When casting music playback to a device, the streaming quality settings on that device are respected" from the Amazon Music help page does hold out some hope - it's just that it's been hard to verify that from the devices that currently can be cast to.
Given that the WiiM Mini looks like a fully fledged echo in the Alexa app but does show bit depth and sample rate in the WiiM app (and hopefully bitrate too at some point in the future), we might have the chance to have that bold assertion proved.
I hope they retain access to your own library and playlists like they currently do. The Heos app doesn’t support those for the Amazon Music HD service and while I’ve read that Bluesound does, some other comments I’ve read suggest that it doesn’t.I hope we get there. And someone here can test and confirm true lossless AMHD up to 24/192. Being able to get this capability while casting from the AMHD native app would be a SUPER SIZED bonus... it's light years better than the Wiim Home app.
Luckily I don't really use/create playlists, other than my list of go-to tracks for auditioning/evaluating new gear, set ups, etc. However, I do like the AMHD UI and the albums/artists suggested works pretty well for me. Fingers crossed. For now it's fire tablet USB out to DAC!I hope they retain access to your own library and playlists like they currently do. The Heos app doesn’t support those for the Amazon Music HD service and while I’ve read that Bluesound does, some other comments I’ve read suggest that it doesn’t.
Except there is no definition of what's "Alexa-enabled device" mentioned on this page means. The page used to link to a generic search page with various Amazon devices listed (e.g. Echo Dot) but that has been removed recently. So far, I have not encountered any "Alexa-enabled devices" which can output Amazon Music HD/UHD digital stream untouched.The statement "When casting music playback to a device, the streaming quality settings on that device are respected" from the Amazon Music help page does hold out some hope - it's just that it's been hard to verify that from the devices that currently can be cast to.
For me, a device is Alexa-enabled if it interfaces to Alexa, or if it is visible to Alexa, most commonly thru the use of an associated Alexa skill for the purposes of being controlled by Alexa. I’d say, for example, that my Heos Link HS2 is Alexa enabled since, thru its skill, it appears as a speaker that Alexa can direct audio to. It also plays bit perfect Amazon Music HD/UHD tracks, albeit not via Alexa.Except there is no definition of what's "Alexa-enabled device" mentioned on this page means. The page used to link to a generic search page with various Amazon devices listed (e.g. Echo Dot) but that has been removed recently. So far, I have not encountered any "Alexa-enabled devices" which can output Amazon Music HD/UHD digital stream untouched.
Heos app definitely does NOT, and it's frustrating as heck. I recently found a way around it for my familyroom system - enable Alexa on my new LG TV (optical out to my Denon AVR) and cast to it like I do for the WiiM.The Heos app doesn’t support those for the Amazon Music HD service and while I’ve read that Bluesound does, some other comments I’ve read suggest that it doesn’t.
Jitter is irrelevant here.that s just 50% more jitter than the small cca ..2015... not expensive too
So I understand from an earlier ( last year) deep dive into this. Sad state of affairs that the only device that can provide basic CD quality streams is a decade old piece of long discontinued hardware. It’s truly bizarre that Apple promotes Apple Music having lossless coding but does not provide any way for a user to stream this to current hardware. Assuming this is all correct and one of their many software updates over the past year has not fixed this. Have not read of a recent test verifying AirPlay 2 still compresses Apple Music lossless streams.Airplay 1 with an Airport Express will get you lossless ALAC 44.1/16
you have mesureaments of jtest with rme in toslink, not usb?Jitter is irrelevant here.
Like I mentioned before, hook it to an RME ADI-2 optical input and run J-test and you won't see any on the DAC output.
The only important thing for the optical source is bit perfect transfer from source to DAC digital input.
After that, it is all about the DAC.
RME has them. SteadyClock FS, which the ADI-2 DAC FS uses, all but eliminates jitter on the optical input, as seen in this video.non
you can observ
That's your problem. You wanted measurements via the optical input on the RME. You have them.i dont have rme....
