wiim is a toy and we are beta testers i thinkits not really reliable , signal drop, bit perfect output flaky, it just breaks the music trance
100% works for me and 100% reliablethe rest just want it to work and be reliable!
But you can buy an MQA decoder over optical, and it will work.Me got E50 which is MQA renderer over optical . So that no work
It's probably your networking
That was my issue initially too
i have no problems streaming 4k HDR , Mac to USB to dac , no problems, i have 5Ghz exclusive, and im a software engineer ,so its not me network, also wiim mqa beta stuttered and screeched like nails over chalk board screechhhhh!!And everytime I get a problem I instantly jump onto a speed tester (in favaourites and on it in 1/2 a second) and I'm sure you can guess what the results are.
The fact others are reporting it as well and I'm guessing they're not havng problems streaming Hi Def from Netflix / Amazon bearing in mind video is massively larger than music files.
Exactly, it should work , maybe they have put in too many features , just Amazon Music, DLNA, and Tidal enough.Why they need to enable everything on the planet i dunnoI know there are a lot of "Fan Boys" out there but I'm 100% with you on this!
I'd literally just sat down at the end of an evening to relax and start started playing some music and switched on my laptop to look through the forum and the music just stopped ...... I did check it wasn't the Amazon App 1st and it wasn't.
Whilst this is potentially an outstanding piece of equipment for the price at the moment it's little more than a toy and the people that have bought it .... as you say and I've mentioned at least 2/3 times previously are just unpaid testers.
I mistakenly thought it was a Chinese product / company and previously mentioned how many Chinese companies seem to have little regard for their buyers and just treat them like testers delivering sub standard products and using their buyers as early stage testers that "The West" wouldn't find acceptable.
At a later stage, someone from WiiM commeneted they were an American company .... however they had a lot of senior Chinese staff .... seemingly trying to infer it wasn't run the way some Chinese companies seem to be.
If I was a betting man, I'd say the whole finance for this comes from China and they believe a US address lifts them to a higher level of credibilty but they still adopt the same way of running it that's seen as acceptable in China and if funded by them that's the way it'll be done irrespective of the address.
I have absolutely NO INTEREST in being their unpaid tester, I just want it to work FULL STOP!
If they actually want to take this product to the next level they need to understand their market, the Audiophiles / people happy to tinker with things like rasberry pie and are happy to be testers is probably less than 1% of the people that listen to music .... the rest just want it to work and be reliable!
This , i mean over DLNA also, too many issues.Anyone else seeing the last few secs of songs go silent on DLNA occasionally??
Same for Bubbleupnp and hifi cast.
I’m sure it’s been mentioned here that that DAC works ok at 24/192 (try searching the thread) withWiiM - can you try another cable? I presume you’ve done the spdif setting tests in the appHey everyone, new to the WiiM party (was using an iPod Touch into integrated amp) but having no sound at 24/192 when I'm running via Toslink through a Schiit Modi 3E, which according to specs should be able to handle it.
Is there something I'm doing wrong? 24/96 works fine.
Thanks, I was just using the cable included in the WiiM box.I’m sure it’s been mentioned here that that DAC works ok at 24/192 (try searching the thread) withWiiM - can you try another cable? I presume you’ve done the spdif setting tests in the app
Hmm the Schiit Modi 3E specs say "Sample Rates and Bit Depths: 16/44.1 to 24/192 via USB, Coax, and Optical" https://www.schiit.com/products/modi-1the toslink was originally not made to pass more than 96k..
can be your dac on this format can not receive more
I just want to mention, I have an Amazon Echo Link and it displays the exact same behavior.One issue with Amazon Alexacast is that after a while my Amazon app disconnects from the Wiim while playing and I have to go to the Wiim app to control the stream. It's like there's a timeout or something. Spotify Connect is still the gold standard. I sure wish Spotify would go lossless
Pretty sure it happens with my echos tooI just want to mention, I have an Amazon Echo Link and it displays the exact same behavior.
Spotify HiFi coming soonOne issue with Amazon Alexacast is that after a while my Amazon app disconnects from the Wiim while playing and I have to go to the Wiim app to control the stream. It's like there's a timeout or something. Spotify Connect is still the gold standard. I sure wish Spotify would go lossless
