Which dac that does full mqa optical/coaxial?
I just mentioned few posts up - SMSL M500 Mk2
SMSL DO200
Sabaj A20d 2022 version
Many thanks for taking the time to explain! Now I get it!Tidal app with USB DAC (or USB to optical converter) directly connected - Tidal app does 1st unfold.
Tidal app casting via Tidal Connect to WiiM Mini or any Tidal Connect streamer - never does 1st unfold, with any hardware.
So what you are seeing is completely normal.
There's no issues.
Just wait for WiiM Mini's MQA Core Decoder update in next 2 months. Then your E50 optical input will perform as MQA Renderer because the Core Decoder is WiiM Mini
WiiM Mini will then function like a Bluesound Node optical output, with Tidal Connect
I think your confusion comes from misunderstanding how unfold is currently working with your current stuff. And how it works with other streamers.
I have a Bluesound Node here so I know from practical experience.
Maybe the reason gustard x16 is two times more than e50 due to it can perform such function plus other features. My question would be mqa core + dac renderer which will be full mqa unfold same sound as usb full mqa unfold? I just don’t want to connect a laptop on e50 just to get full mqa because I can’t control it.Tidal app with USB DAC (or USB to optical converter) directly connected - Tidal app does 1st unfold.
There's no issues.
Check out prices of those others I mentionedMaybe the reason gustard x16 is two times more than e50 due to it can perform such function plus other features.
Instal tidal on desktop and use tidal connect on my iPhone to control the desktop app?Check out prices of those others I mentioned
Yes it's the same bits at the end. How you reach the final sample rate is irrelevant.
One advantage of WiiM Mini doing your first unfold (with firmware coming) feeding an E50 is perfect optical galvanic isolation.
Control using Tidal app + Tidal Connect
That’s not possible eitherInstal tidal on desktop and use tidal connect on my iPhone to control the desktop app?
The perfect service would be Tidal interface with Spotify connect and Amazon (or Qobuz) files. Obviously at 9.99(€/$/£)That’s not possible either
Yeah sorry from LMS. I also could only get it working in flow mode. Glad to know I didnt do something wrong.WiiM is a player just like pCP. But if you've meant gapless streaming from LMS to WiiM it's only possible with squeeze2upnp in "flow" mode at the moment.
Or if you've meant a WiiM app it's dedicated to WiiM Mini only.
This would be like Spotify ConnectInstal tidal on desktop and use tidal connect on my iPhone to control the desktop app?
6 months ago, I asked them for some features as spot conn does, like for example, control a playing device from another but they answered it was not on theirs plans...This would be like Spotify Connect
1 year ago Tidal Support told me this was coming "soon"- still hasn't happened
I've been using a Chromecast Audio as a sort of "portable" music player (that requires power) around the house with a set of headphones, and when I saw your comment about BubbleUPnP making it gapless I had to check, but as far as I can tell, it doesn't. The 'Gapless playback' tickbox isn't there for the Chromecast Audio and if I proxy it to an OpenHome renderer it definitely isn't gapless. Am I missing something?
You can do gapless, but not from DLNA. The workaround that Bubble uses is to buffer it all on your device and send it directly from there. That's why the warning on battery life.You are right, apparently I confused CCA with some Cambridge Audio streamer. I've just checked and indeed CCA does not support gapless playback with the BubbleUPnP server.
Most Spotify users are using their phone and as long it produce sound to get them by is all that matters. There many people can’t hear difference between hi fi and mp3. The percentage of audiophile among Spotify user with good system are slim. In fact more people joining even it’s just mp3 quality. As for features and convenience including a remote to desktop and connect they are on the top.If their subscriber numbers continue to climb, I doubt there's any urgency
Maybe initially they thought it was urgent when Apple and Amazon made their hi-res moves but look at recent numbers, maybe they have lost the urgency, possibly
Spotify’s subscribers rise to 188M amid podcasting setbacks
As it contemplates an entry into audiobooks.www.theverge.com
