WiiM Mini Streamer
Not sure what you mean by that, WiiM has already a built DAC to feed the analog output. Probably you are meaning something else that I haven't grasped?.
I have a Node and if I have to buy any streamer today to feed my DACs, I would go with WiiM. Simply, the price difference is too high, and the extra functionality in Node is not compensating, from my point of view.
Sorry I meant a quality DAC. The built in WiiM mini DAC is subpar ( not for the WiiMs cost and if playing highly compressed music maybe usable, but I listen to Spotify and Apple Music both compressed at present and found even an inexpensive quality external DAC makes a significant difference.
Also a WiiM mini pro with metal housing, a better power supply, full USB output ( USB C or regular USB input, not the mini/ micro usb) could make sense in terms of materially improved hardware. No need to upgrade the internal DAC as many folks already have DACs including some built into Amps, along with inexpensive external DACs freely available.
So bought one of these today....noticing a fair amount of audio skipping / stuttering
Wasn't sure if it was an Apple Music buffering issue so just threw a pink noise youtube channel on and yeah, random skips & blips :(
ON THE PLUS SIDE: Way, way better performer than the Apple TV. With that I can crank volume on my amp and pick up noise, clicking, and other dirt buried in the signal. Changing source to this at the same volume and the noise floor goes way down, below my DAC's floor. But yeah, the stuttering is making me want to return this junk now, noise floor means nothing if it cant play music competently.
Most likely a WiFi issue, either weak signal or interference. It can definitely perform competently with a good, clean WiFi signal.
App says device wifi strength is 'very good' / 5ghz only, etc.
Restarted router & all devices
skippin' like a schoolgirl
Reset WiiM mini ( Restore Factory settings) and try again.
I have had the same skipping issue starting Saturday, since my firmware updated. Reported to Wiim support. This is what I got back from them - " It's probably related to our recent changes in the AMHD buffer handling." They are working on it.
No dice, but for a moment, I had hope
ahh crap, and since it auto updated out the box I have no idea if things were better before. Hopefully they figure it out within my return window (if this is what's causing it)
...and yet, I've been playing from Amazon HD for hours on end, with the latest firmware, without a glitch... I doubt it's a firmware issue - WiFi or router issue is much more likely.
Could this be a result of the DAC Toslink connector? Some DACs have drop out issues when Toslink is used as source. What DAC are you using?
DAC has no problem with the ATV (Jitter machine) using Toslink. The DAC is a NAD M51. ¯\_(ツ)_/¯
If playing high res audio that is already on a Toslink connection limits in terms of bandwidth, I wonder how much a splitter degrades the sound. If listening to compressed formats a splitter should be fine.
My dac shows sampling frequency and I get bit perfect changing one dac to other including 192khz
My take on dac sound signature. AKM fully body strong bass and mid and little treble that could be dull on some music, It’s lay back sound. ESS very detail and forward sound with some digital glare. Multibit sounds like everything I play like they where cassettes tapes.
I can see how else you could acheive it, you can buy audio / video splitters but that's not going to give you anything different to the projectors analogue out, if you do go bluetooth transmitter get an APTX one as the reduce latency.
Would a 2nd WiiM transmit the audio via Airplay? Would that yield lower latency? A basic bluetooth transmitter is pretty cheap, but if a second WiiM gave me better performance I’d be happy to go that route.
Enable the 8.8.8.8 DNS setting in WiiM Home app.
Any difference?
Powering WiiM properly ?
Any difference?
Was using 8888 the whole time (then tried without after the factory reset, no diff)
Not sure how to power improperly here but I tried the USB cable direct into my power bar's USB power and with the provided adapter into a separate outlet
Well the user manual states 1A at 5Vdc so if someone powered it from a USB 2.0 port, that is technically improperly right?
USB 2.0 powah = 0.5A (may work, but may not)
If using their supplier adapter then obviously that's proper
I experienced random problems when I moved the Puck behind the amplifier chassis (from other room router's point of view). Even the signal reported was still good, I think the wiim had problems to answer back to router. Then I relocated in a less "covered" position (30cm) and since that connection glitches gone. Maybe is something like this...
USB cable directly into my power strip's built-in USB charging port, tried this one too initially and it failed miserably (WiiM booting unstable and system crashes). Was told by WiiM support to use supplied charger instead and it worked.
For those of using the optical out, what optical cable are you using? Have you noticed any improvements by using a cable better than the WiiM supplied cable?
Thanks! JMac
