I run Lyrion on a rPi 5, and Daphile also runs Lyrion.
I can confirm that with Lyrion's "UpNP/DLNA Bridge" plugin enabled, the WiiM Mini works perfectly as an endpoint ... though there's one very important configuration necessary - in the Lyrion server settings, under "UPnP/DLNA bridge" change the "Gapless" setting from "Yes" to "Force". Without this simple change, Lyrion will play OK, but when you use the "skip" function it will advance two tracks ahead, and it will also fail to seek through individual tracks.
It's a long time since I tried Daphile, but I suggest you avoid both the Daphile interface and the WiiM interface. Instead use the highly regarded "Material Skin" interface - in a web browser go to
http://daphile.local:9000/material
I'm guessing you mean "WiiM Mini" not "WiiM Amp". I don't think the WiiM Mini will show in the audio devices menu, because in this situation it's a
streaming renderer, not a "device". No problem, the WiiM Mini will show up in the Lyrion setup interface as a valid player/endpoint - click on the 3 horizontal lines at the top-left of the Lyrion interface.
Here's my Lyrion server streaming 24 bit 192 kHz audio files to a WiiM Mini -
https://craigsaudio.blogspot.com/2026/04/raspberry-pi-5-lyrion-07.html
