mikeTRON250LM
- Joined
- Dec 25, 2021
- Messages
- 12
- Likes
- 1
Folks that are using this, what are you streaming from?
I've been using it with Spotify & Tidal, accessed from Wiim Home app.Folks that are using this, what are you streaming from?
I’m using Audirvana through uPnP. Handles my hi res files on NAS including DSD64. Able to play Tidal Masters MQA through WiiM to DAC up to 96/24. Remote control from iPhone appFolks that are using this, what are you streaming from?
I have some questions:
a. I can cast directly to the streamer from Spotify app in my windows 10 PC. But Spotify in my android phone cannot connect to the streamer (either from Spotify app or from Wiim Home app). However, Tidal from Wiim Home app can connect to the streamer.
b. when it's streaming music from either Wiim Home app or from my desktop, the music often stops for a few seconds every 5 minutes or so.
Is it likely to be a wifi connection problem? the wifi status in Wiim Home app sometimes says 'weak' although it's fine with my other devices. I tried to connect the streamer to another wifi connection in my house. However, I've been unable to do so. I deleted data & cache from Wiim Home app and then uninstalled. But when I installed the app again, the previous wifi connection is still there. How to connect to another wifi connection?
How is the WiiM Home app control of local files (on smartphone) playback: does it support fast forward/rewind the track currently being played?
Is the EQ working only on local files playback?
So, EQ works with local files playback, what about Spotify connect?You can drag the song progress slider back and forth, and EQ seems to apply to all sources
If thats working.... seems to good to be true
Question for WiiM Mini owners: when turned on, does it produce coil whine (high pitch noise) audible from 5-10cm of device?
Guess only WiiM can answer that - have you raised a ticket to ask them?What does this means? MQA bypass was changed to ‘no MQA’.
@WiiM Support can you clarify?Guess only WiiM can answer that - have you raised a ticket to ask them?
I tried linking an Amazon account to Wiim Mini, and I was disappointed that the app opens an embedded browser for logging into the Amazon account. This kind of setup is insecure, because the app is able to capture passwords from embedded browsers and use the Amazon account for purposes it was not intended. Google has actually forbidden this and apps that do this for Google accounts will be removed from Play Store.
One proper way to do this is to open the system browser for logging into external accounts and return to the app afterwards. The system browser is trusted to handle external service passwords.
