wiimhome.com
Hans Beekhuyzen did measure a fault on the WiiM - a sudden peak of + 0,6 dB in the treble area from the analog out of the WiiM . If that was a hardware bug its not good. I hope Amirm can do a frequency response measurement to verify if that peak exist or not.
Dust mites farting sounds like a direct lightning stike on your house compared with -300dB.-300dB must be the level for those "hearing" their dust mites farting![]()
My experience: WiiM mini (TIDAL Connect) to Topping E50 DAC to Topping PA5 amp to (efficient) speakers make a wonderful budget ‚highend‘ chain. I don‘t miss a thing!
My Wiim player works fine with any mobile phone charger and the supplied cable.Seems fine to me, but one question (just curious): is the device generally incompatible with USB-C charging, or is it only the higher power requirement that prevented it from working with your USB port?
I use a pair of Sjöfn (the clue). They are, in terms of concept, similar to the standmount speakers from Guru Audio.@SunnyRehde thank you for practical view. Can I ask which speakers are you using?
The app is used for setup and accessing most if not all of the supported services apart from Spotify Connect and Tidal Connect.is the app only for setup or do you actually need it if your just using spotify connect etc?
Good example of how missleding and non telling this FFT graph can be.
It isn't important.Why is Roon important?
How?Happy to see such performance, especially cause I've purchased it for 25 instead of regular 100€ price on Amazon![]()
