Wiim announce WiiM Amp Ultra
No. The WiiM Ultra and Amp definitely support both mass storage and USB DACs.
I don't see why this would change for the Amp Ultra.
Interesting, have you got Wiim Ultra or Wiim Amp to confirm with a quick test?
Their documentation does not say it supports USB DAC input, it only shows storage or USB Audio out to a DAC.
I don't understand. A DAC cannot physically output audio via USB. No matter to which device.
If it could, it would no longer be a DAC.
Edit:
Just re-read your original post and yeah, I misunderstood sorry.
The WiiM Amp/Ultra support USB Audio output to an external DAC, but cannot themselves act as USB DACs.
I doubt this will change for the Amp Ultra.
The term "chifi" isn't allowed here. I've only seen one person who has a problem with it, but he's the guy who owns the site so the polite thing to do is obey the rules. Use something less contentious; "cheap and/or low quality Chinese audio hardware" for example.
...he's not the only one who objects.
Edit:
I had to return my Wiim because of this only, Wiim app on Windows had so many issues and Wiim support confirmed me when I checked with them. Their focus wasn't for Windows products at that time (and perhaps it's still same), and lack of USB DAC feature was show stopper for me.
Anyways, it is what it is.
Reactions: KLi
Looks like that got pulled? I get a 403.
Nah, Darko has blocked direct links from ASR as pointed out above. Copy the link and paste it in a new browser tab and it works just fine. Or just don't patronize Darko's site, since he's obviously an extremely petty person.
One of the main audio quality advantages of the Amp Ultra vs the WiiM Amp Pro seems to be 100watts at 8 ohms vs ~60watts? Should we expect to see improved SNR and improved treble distortion in the new Ultra AMP (not that the Amp Pro looked bad?) I was planning to buy the Amp Pro for 4 zones in my house where I'm driving 8 inch B+W in-ceiling speakers with sensitivity of 89 db, and the rooms are not that large- about 12 x 15 x 8 ft. The amps sit in a central rack in the basement and I control only via an app so the screen isn't useful for me. And in two of the rooms I am using a powered subwoofer as well which helps offload the amp. I am guessing the Amp Pro is probably plenty for this scenario and the incremental value of the ultra would be negligible- does that sound right? (I know it's hard to be completely sure without measurements but the AMP Ultra seems to be predictable in this regard based on the Ultra and Vibe tests.)
@ZinMe I would say the Ultra will provide no real advantage for your setup and the Amp Pro will work very well.
Wiim amp ultra
Looks like wiim have announced the obvious next stage in their extensive lineup, a streamer/amp combo. Just one high performing device sounds good to me, though some of you may require higher power. I certainly don't in my small lounge. Amazed they've essentially merged an ultra, and an amp into the same dimensions. Hope it has vents.
I appreciate that picture is arguably a staged one, but a AT3600L set in a solid-plinth deck plonked on a resonant shelving unit and a KEF LS50? also plonked on there for visual effect... Sorry folks, the remaining dealer in me goes mad when I see setups like this, even if they are merely for show...
Wiim seems to be available via dealers in the UK, unlike the other favourites around this price, so I with this new little box all the very best and hope its performance is good too :)
There won't be any resonances, as there won't be any unsightly cables used.
Wiim also announced an active sub.
3 announcements from Wiim today.
Amp Ultra
Sub Pro
Sound
Nice specs for such a small device. Looks good.
I would love to have a 10-band parametric EQ on my ampliifer, much better then Dirac.
Key Features​
  • Powerful Amplification
    • Delivers 100W per channel at 8Ω or 200W at 4Ω—easily drives up to four passive speakers with stunning clarity and dynamics.
  • Audiophile-Grade Components
    • Features the 32-bit/384kHz ESS ES9039Q2M SABRE DAC, dual TI TPA3255 Class-D amp chips, and six TI OPA1612 op-amps for ultra-low distortion and rich, detailed sound.
  • Post Filter Feedback (PFFB) Technology
    • Ensures stable, load-independent performance across all speaker types—delivering cleaner sound and improved amplifier control, especially with complex loads.
  • Next-Gen Connectivity
    • Equipped with Wi-Fi 6E, Bluetooth 5.3 with LE Audio, and dual antennas for fast, stable streaming across all wireless protocols.
  • Elegant Touchscreen Design
    • Housed in a premium unibody aluminum chassis with a vibrant 3.5” glass-covered touchscreen for intuitive control and stunning aesthetics.
  • RoomFit Room Calibration Built-In
    • Advanced room correction technology analyzes your space and customizes output for speakers and subwoofer to optimize soundstage and tonal balance.
  • Exceptional Sound Performance
    • Achieves -105 dB THD+N and 120 dB SNR at 5W—ideal for high-fidelity playback across any genre or setup.
  • All-in-One Streaming Hub
    • Stream music, podcasts, audiobooks, and internet radio in Hi-Res up to 24-bit/192kHz directly to your speaker system.
  • Universal Music Service Support
    • Seamless access to Spotify, Amazon Music, TIDAL, Qobuz, Deezer, Pandora, iHeartRadio, TuneIn, and more via the WiiM Home App.
  • Cast with Ease
    • Supports Google Cast, Alexa Cast, DLNA, Spotify Connect, TIDAL Connect, DLNA, and Roon (certification pending) for effortless playback from your favorite apps.
  • Flexible Input Options
    • Connect turntables, TVs, or other sources and broadcast audio wirelessly across your multi-room system.
  • Cinematic TV Audio
    • HDMI ARC, Dolby Digital decoding, and dedicated subwoofer output bring immersive home theater sound to your living room.
  • Smart Voice Control
    • Works with Alexa, Google Assistant, and the WiiM Voice Remote for hands-free playback and system control.
  • Customizable EQ
    • Fine-tune your audio with parametric and graphic EQs tailored to your own preference.
  • Future-Proof Experience
    • Receive ongoing firmware updates with new features, services, and performance enhancements.
  • Home Theater Integration:
    • Functions as the front, surround or center channel speaker in a Dolby 5.1 setup
  • Smart Preset
    • Streamlines the listening experience by offering quick access to frequently used content and settings.
  • Alarm Clock
    • Set the alarm time, occurrence, and choose from various music sources.
