www.audiosciencereview.com
good to know, looks like a few Wiim's do this I didn't know about
compare Wiim Mini to LP10:
both have AirPlay 2
LP10 has Chromecast audio
both support AUX in & out, S/PDIF (optical) output
WiiM Mini also outputs S/PDIF coax
Mini more RAM faster CPU
LP10 accepts S/PDIF (optical) input
LP10 has a LAN port
LP10 has a remote
LP10 has a display
LP10 has Bluetooth 5.2, USB-A
No. While Arylic and WiiM have a common pedigree thru Linkplay (the former use Linkplay SoC modules while the latter also do as Linkplay’s in house brand), they don’t share the same level of firmware and features. From a quick glance, Arylic’s feature set pales in comparison to a WiiM Mini.I am not familiar with the Arylic LP10. Does it provide provide the option of applying Parametric EQ and room correction like the WiiM Mini ?
Did you use AI to generate that list, it's full of inaccuracies.compare Wiim Mini to LP10:
both have AirPlay 2
LP10 has a LAN port
LP10 has a remote
LP10 has a display
No, please LMK be happy to correctDid you use AI to generate that list, it's full of inaccuracies.
Mini doesn’t have coax output and can support the WiiM remote.No, please LMK be happy to correct
Mini does Bluetooth.No, please LMK be happy to correct
The Wiim devices can also connect wirelessly to each other, so adding airplay does not need to use a physical input.Updated the comparison.
Yes, sticking to Mini as they are similar price, idea is still "add Airplay to the Ultra" maybe some feature closes the deal OWOTO
Obviously keeping within Wiim ecosystem is inherently attractive for some
Yes, Arylic streamers are discovered in Wiim app and vice-versa with 4Stream app.I wonder if the Arylic and Wiim devices can connect using one of the audio-over-WiFi protocols?
How do clients receive that way from such devices, in a non-proprietary way if one is avoiding BT ?
Excellent, thanks! Any links explaining details on whatever WiFi-specific protocols are involved there (both directions) and in listening via Android clients, would be appreciated...Yes, Arylic streamers are discovered in Wiim app and vice-versa with 4Stream app.
Basically Arylic and Wiim both use same base platform and discovery works simply using UPnP, you will notice most similarities between both the apps.Excellent, thanks! Any links explaining details on whatever WiFi-specific protocols are involved there (both directions) and in listening via Android clients, would be appreciated...
WOW that's a LOT more than I expected!Wiim Home will discover both Wiim and Arylic devices and then you can do whatever you like. You can pair them in Primary/Master + slave for multichannel setup or use for multi-room streaming over WiFi.
