WiiM Amp Ultra Streaming Amplifier Review
Rate this streaming amplifier:
    Votes: 4 1.1%
    Votes: 9 2.5%
    Votes: 71 19.9%
    Votes: 273 76.5%
I use the streamer I use the analog in for my phono pre ( not the built in phono ) , I think I'm good. if something is not perfect it can be use case dependent if it is a problem.
The "perfect" devices in the upper end of the blue part of the chart can never be an issue for anyone .
The ADC in the streamer has close to 100dB signal to noise, the Sinad is lower around 87-85 dB because some distorsion spikes but i use it for my Vinyl player with typical close to 1% THD in the pickup
https://www.audiosciencereview.com/forum/index.php?threads/wiim-ultra-streamer-preamp-review.57342/
If the mac and the phone are in the same network, the WiiM is available to them as a receiver. No need for a direct connection to listen to music.
I have seen stutter of dsd hires files over a wifi farer away on 1-2 bars. That's where a lan cable for the WiiM is better.
I've both Wiim Amp Ultra to pair it with my Dali Opticon 2. It was very bad combo. Amp Ultra made speakers sound really bad, the sound was washed out, no dynamics at all. I've contacted the seller and he agreed to test other units with my speaker ( in case mine was faulty). All gave the same results. We tried changing cables, all sort of things in Wiim software with no significant improvements. Both of us were very disappointed. After that we tried some 350$ Denon amp with Wiim Ultra as DAC and it sounded grate.
If I haven't heard my speakers before connecting to Amp Ultra I would have been really disappointed with them since I've been convinced that Wiim Amp Ultra is excellent device. Now I know better.
I've tried Wiim Amp Ultra with Monitor Audio Bronze and it sounded much better than with Opticon. That leads me to conclusion that device is load dependant contrary to specification.
The WiiM Amp Ultra sounds the same to me as my Purifi amp powering my Dali Rubicons. However, I also don't hear differences in optical vs coax cables or different kinds of power supplies on my DACs.
The WiiM Amp Ultra works great with all speakers I have tried (Dali and Philharmonic). I would highly recommend this device as a great price for an all-in-one setup.
I have had similar positive experiences with both my Kef LS50 and Wharfedale Linton 85. They both dip below 4ohm and both sound great. I have two WIIM amp ultras driving them.
Then it's all good for you. My experience is not the same. Maybe both Amp Ultras were malfunctioning or we have totally different definition of acceptable sound. Whatever it is, my advice still stands: try speaker and amp combo before buying.
Kind regards.
Kind regards.
Your advise is reasonable and has been same for so many years but trying speaker and amplifier combo before buying might not be possible in many cases and even if it is possible then those audition rooms aren't same as ours.
Closest you could get is buy it with decent return policy and then use at your place to decide.
Kind regards.
I think you might be very used to that $350 denon sound.
Yeah, you've got me. I just love that $350 sound. ;)
Didn't mean it in a negative sense. I own a stack of amps myself and know what they can and can not do. The difference being mostly the very basic or mediocre preamplification and signal processing.
I am curious why the SINAD performance is better with the digital input than with the analog input. The digital input has to pass through a DAC in there somewhere right? SO how do we compare digital vs analog input cases? This doesn't seem possible, so I must be misunderstanding something.
The analog goes trough an ADC as every other function is sorted by an DSP , it’s basically a digital device with an analog input.
I use this to my advantage have an old turntable and speakers with digital inputs so this works for me .
Yes it's a not quite SOTA ADC implementation.
I doubt you can actually hear a difference, but using say PocketADC to test would not be expensive.
The Wiim Ultra headphone output is a weak link for sure though, many use the USB output to a better DAC/HPamp unit for that.
I canto seem to find a review or the Wiim ultra non amp version
To find the reviews on this site enter "WiiM Ultra" into search, tick titles only and from user: amirm
Other users do reviews too. Search just for titles and no username usually does not give too much hits and all is there.
I use it as my main 2 channel preamp for this very reason, and to me it sounds fantastic. Those Burr-Brown chip is as smooth and rich to my ears as I could want.
