WiiM Amp Ultra Streaming Amplifier Review
Rate this streaming amplifier:
    Votes: 4 1.1%
    Votes: 9 2.5%
    Votes: 71 19.7%
    Votes: 276 76.7%
Shame it doesn't have enough Coax/Toslink inputs for my use case.
I wish they'd make some USB controlled extra inputs like a coax/toslink input switcher to stack with the ultras and integrate with the control app. If you don't use the ARC input there's the Sonos toslink to ARC adapter which should work, though I haven't tried it.
Are you sure that is fact? or something AI made up?
My search results imply it is necessary to go through USB DACs to get those?
It's been my experience with an Ultra. I don't have an Amp Ultra to try it with, hence the assumption. I guess the AI in your search was hallucinating.
It is a fact. You can attach a passive or a powered USB hub to the USB port of the WiiM Ultra or the WiiM Amp Ultra, and any storage device or DAC you attach to that hub (assuming it does not require more power than a passive hub can provide if you don't do a powered hub) will work. It will not allow the WiiM to act as an external DAC for other devices, but it will allow you to attach an external DAC, a storage device, or a DDC into each hub port and they will show up in the WiiM.
Can i attach a USB DAC to the USB port so i can have USB-C audio in from my laptop too?
What bitrate does WAU USB port support?
What is the best 5V USB DAC that can be powered by the port?
You cannot use the USB port on WiiM Amp Ultra or WiiM Ultra as digital audio IN. It is only usable for attaching storage or for digital audio OUT (WiiM streaming to an external DAC, not acting as an external DAC for a different digital source, such as laptop). The competing Eversolo Play does have this ability, but its integrated amplifier is likely to be less performant (based on the fact that far more expensive Eversolo Amp F2 is outperformed by WiiM Amp Ultra).
But USB converters can route to S/PDIF input
Correct; you can use a USB DDC with your source that has USB out to convert to Toslink. Cubilux makes inexpensive ones, or you could get something like a Douk U2 (Pro).
AI
Fixed Volume (Recommended for Quality): Sets the WiiM output to 100% (bit-perfect) and uses your amplifier to control volume.
But is it also volume limit or only fixed volume for bit perfect ?
AI
That does not guarantee bit-perfect output, it only guarantees no separate digital volume attenuation, but turning on ReplayGain, using RoomFit or (P)EQ will still, “change the bits,” even with volume fixed. Any internal resampling will also, “change the bits,” even with volume fixed, such as trying to play DXD or DSD material.
Fixed volume is necessary for bit-perfect but not sufficient, you must also disable ALL other DSP.
They just emphasize the volume because many do not realize that activates DSP, thus disables bit-perfect pass-through
While true, "bit perfect" is not necessarily synonymous with "best possible sound". :-) Also consider that many devices internally have more bits available than the original encoded audio. If the track is -let's say- 16 bits, you can use the rest for volume control without modifying the "bit perfect" stuff, so you can have both.
Purists hate this one weird trick...
Are you speaking for all of them?
I am not sure it's a trick, it's just the stuff digital tech allows one to do safely. And we should get used to it, too. Many great measuring DACs or amps use digital volume controls. Ask Benchmark or such...
It's a joke/meme. I agree that many take the bit-perfect issue way too far.
I haven't read the thread here, but I tried the Amp Ultra. I really disliked it. I connected my Mac to it via optical, since it has no USB input, and it was really disappointing to just see "Optical Input" on the screen the entire time. The feeling of the knob was a real let down. My father had 1970s Yamaha and Marantz gear when I was a kid and to me a stereo must have a satisfying volume knob, the amp ultra does not satisfy that requirement. Then I connected it to my subwoofer, and there was a very loud hum, I assumed it was a ground loop, but I couldn't solve the issue, so I tested the subwoofer out port and on standby it had 228mV of current. I'm assuming it was a defective unit, but it made me pretty hesitant to try anything else my WiiM, although I'm considering the Vibelink (I understand the volume knob has an actual potentiometer).
You can change it
Have heard about the ground loop
Wiim sub pro you can connect wireless
I mention it.
The feeling of the knob is mediocre compared to the vibelink
I hoped i could somehow use a normal subwoofer but looks like i have to buy bigger speakers like the wharfedale diamond 12.2i, if i want deeper bass
No sub out on a vibelink
Also as mention somewhere else, i have set output on my stream to 100% but adjusted volume limit (80%) that match my wharfedale diamond 12.1i pretty good and theres no distortion even at max spl when my woofer moves alot do to heavy bass, that why i can use a subwoofer, it's not adjusted using the vibelink amp
Also as mention somewhere else, i have set output on my stream to 100% but adjusted volume limit (80%) ...
If you have the output volume of your WiiM streamer at 100 but the volume limit at 80 %, then the output is not bit perfect, of course (if this was your previous question). Does this matter? I don't think so.
You can change it
"Big Butt" Lester has been referring to the physical optical input. The optical input has no concept of what is currently playing. There is no meta data contained in the S/PDIF signal. This is the same for all optical inputs on all devices.
More pics of the insides of a WiiM amp ultra.
Overall very nicely built, substantial heatsinks on the power supply, albeit using like 10mm thermal pads to connect them to the top of the case. I'd expect no more than 5-10 years life out of it looking at the electrolytics, which seem to be B/C-tier except for a few Rubycons.
Recommend to use a switched socket and just cut the mains power when it's not in use.
Also coaxial ?
Makes sense if it's youtube but not from the tidal app but from tidal connect there is
80% i limit it to but triede 100% and just at medium volume it gets loud by going to 100% limit i have 85db (diamond 12.1i) speaker but the 20% or 25% increase makes the amp super loud when i use all of the power, my speakers can handle it but i don't wanna do that for a long time
Im super surprised of how much bass i experience at high levels (room corrected, to almost flta but i don't think it's by more than 1-2 db but bass is punchy at many dfifferent levels, including high levels where it doesn't lack bass, no dynamic compression)
