WiiM Amp Ultra Streaming Amplifier Review
Rate this streaming amplifier:
    Votes: 4 1.1%
    Votes: 9 2.4%
    Votes: 76 20.4%
    Votes: 284 76.1%
This is a review and detailed measurements of the WiiM Amp Ultra stereo streaming amplifier. It was sent to me by the company and costs US $529.
WiiM Amp Ultra Integrated Stereo Streaming Amplifier PFFB digital roon review.jpg
I was surprised how heavy and solid feeling the Ultra is for its size. I upgraded its firmware which went smoothly and rather fast. I was pleasantly surprised by the usability of the touchscreen interface.
I tried to use the App but it would not add the unit yet show it as available. It would not however let me try to see or change its settings. Didn't want to spend too much effort here and just tested it using the front panel.
The rear panel shows the familiar interface we have seen in other WiiM products:
WiiM Amp Ultra Integrated Stereo Streaming Amplifier PFFB digital roon rback panel wifi ethern...jpg
Note that this is one of the few amplifiers using TP3255 class D amplifier IC that has an internal power supply. I also like the inclusion of hardwired Ethernet. And support for Roon player streaming.
A thick manual comes with it but alas, it is in many languages so not much covered there. One thing of note was declaration of security fix period. This is welcome. But not the very short duration of December 31, 2026! Just one year from now??? Best to learn how to setup a VLAN to protect yourself.
EDIT: Online notice now says security updates will be available until December 2029 which is nice.
The included remote is another thing that made me happy especially since it is chargeable using USB-C.
WiiM Amp Ultra Measurements
Let's test the amplifier starting with analog RCA input:
WiiM Amp Ultra Integrated Stereo Streaming Amplifier PFFB Line In measurement.png
This is competitive with other implementations but the real performance is revealing using digital inputs such as Toslink:
WiiM Amp Ultra Integrated Stereo Streaming Amplifier PFFB Toslink Digital In measurement.png
Naturally, streaming provides same performance:
WiiM Amp Ultra Integrated Stereo Streaming Amplifier PFFB Streaming Roon In measurement.png
This lands the Ultra easily in our "excellent" category of all amplifiers tested:
Using post filter feedback, we get one of the best implementations of PFFB on this platform:
WiiM Amp Ultra Integrated Stereo Streaming Amplifier PFFB Toslink Digital In frequency respons...png
No need to worry about speaker/load dependency.
Noise performance is again, one of the best for this platform and even in general:
WiiM Amp Ultra Integrated Stereo Streaming Amplifier PFFB Toslink Digital In SNR measurement.png
Channel separation using digital is excellent as well:
WiiM Amp Ultra Integrated Stereo Streaming Amplifier PFFB Toslink Digital In channel separatio...png
Multitone performance is again, excellent for class and shows the typical rise in high frequencies:
WiiM Amp Ultra Integrated Stereo Streaming Amplifier PFFB Toslink Digital In Multitone measure...png
Which is shown in exaggerated manner when we use dual 19 and 20 kHz tones:
WiiM Amp Ultra Integrated Stereo Streaming Amplifier PFFB Toslink Digital In 19 20 kHz stereop...png
There is a lot of power available here (amp rated at 100 watts into 8 ohm and 200 into 4 ohm):
WiiM Amp Ultra Integrated Stereo Streaming Amplifier PFFB Toslink Digital In Power 8 ohm measu...png
WiiM Amp Ultra Integrated Stereo Streaming Amplifier PFFB Toslink Digital In Power 4 ohm measu...png
I had to reduce the distortion limit to well below 1% as otherwise, it would simply not distort that much:
WiiM Amp Ultra Integrated Stereo Streaming Amplifier PFFB Toslink Digital In Max Power 4 ohm m...png
Again, we have the typical rise in distortion at higher frequencies:
WiiM Amp Ultra Integrated Stereo Streaming Amplifier PFFB Toslink Digital In Power 4 ohm vs di...png
In use the amp just got warm and handled clipping as if it did not happen. No shut down. Nothing. It simply handled being driven to death! Very nice.
And of course, was stable on power up:
WiiM Amp Ultra Integrated Stereo Streaming Amplifier PFFB warm up measurement.png
There is no on off button so I did not run my noise test for these conditions.
WiiM delivers very well featured streaming amplifier with every optimization applied to get the best performance out of the TPA3255 class D amp. Measurements leave no room for complaints but a ton of praise. Beautiful and responsive UI completes the picture of one of the best streaming amplifiers I have tested.
The cost is reasonable for so much power in such a small enclosure with internal power supply to boot.
I am happy to recommend the WIiM Amp Ultra. Company is firing on all cylinders to be sure.
Audio Performance
• Power Output (THD = 0.08%, two channels driven): 100 W per channel @ 8Ω, 200 W per channel @ 4Ω
• Amplifier Technology : Class-D with PFFB (Post-Filter Feedback) technology
•Total Harmonic Distortion (THD+N): ≤0.005%, -106 dB (A-weighted)
• Signal-to-Noise Ratio (SNR) : ≥120dB
• Damping Factor: 94
• Frequency Response: 20Hz – 20kHz ± 0.5dB
• Impedence Range: 2 – 8Ω
Audio Processing
Premium Audio Components: ESS 9039Q2M high-performance DAC, Dual TI TPA3255 Amps, TI OPA1612 op-amps for ultra-low distortion and rich, detailed sound.
Bit-Perfect Playback: Supports up to 192kHz/24-bit audio
Dynamic Range: ≥120dB for high-resolution sound
Input & Output Options
✅ Analog Inputs:
• 1x RCA Stereo: Connects to external audio sources like CD players or PCs
✅ Digital Inputs:
• 1x Optical (TOSLINK) – Up to 192kHz/24-bit
• HDMI ARC: Receives audio from TVs, PCM up to 192kHz/24-bit, and Dolby Digital 5.1 formats
✅ Speaker Outputs:
• Gold-plated binding posts (supports banana plugs or bare wire connections)
✅ USB Audio Output:
• Supports up to 8-channel 24-bit/192kHz; UAC 2.0 compliant
✅ Sub Output:
• Dedicated output for powered subwoofers (RCA Mono)
Thanks for the reviews as always Amir.
A couple years ago I bought a MiniDSP Flex, mainly for the bass management and a bit of room correction in a compact package.
This WiiM Amp Ultra would have served my purpose for the same money and turned 3 boxes, with three separate power supplies into a single, more elegant unit with a beautiful touch screen. Yes, WiiM is killing it!
As expected, the performance of the Wiim Amp Pro versus the Wiim Amp Ultra is virtually identical.
Additional measurements
Thanks @amirm , I have been looking out for this review quite some time!
Worth to mention very good app with ton of features and support for streaming services.
Ive been using amp pro for some time in my living room, one of the best buys.
Amazing piece of kit when it comes to everyday usage being watching TV and listening to music/radio
@amirm,
As a trained listener, consider using the WiiM Amp Ultra to assess the performance of WiiM's RoomFit room correction feature.
yay finally a review of this phenomenal piece of tech.
Kind of invalidates so many other amps, dacs and even streamers. Reasonable price with unreasonably good performance for the price, at least when compared to what we had in the past.
I mean Topping doesn't have bass management so there's that. I hope there's some proper competition to Wiim as they seem to be running away with it lol
This is the review I have been waiting for, thank you Amir. Is there a reason HDMI wasn’t tested?
