somebodyelse
- Joined
- Dec 5, 2018
- Messages
- 6,235
- Likes
- 6,046
I hope not, because that would mean it can't play gapless.2 - Any drift will be reset every new track.
How do you achieve the reset to bring the two clock domains back in sync without a gap or glitch in at least one output?Not the same thing.
At all.
Was your measurement microphone fixed in place for all subwoofer measurements?Recently bought WiiM Amp during Amazon Prime deals, so decided to put some useful information (I hope) for people interested in this little amp.
I was actually building my second audio system in my gaming room to mainly use PC as a source.
Initially I bought Argon Audio SA1 mk2 amplifier together with Dali Oberon 1 speakers and SVS SB-1000Pro subwoofer.
Decided to try WiiM Amp and compare it to Argon Audio that doesn't provide any subwoofer management (high pass filter).
I also compare it to my main class D amplifier Gato Audio DIA-400S NPS (MSRP ~4K euro) which also doesn't provide any high pass filter.
I run measurement sweep using REW together with UMIK-1 microphone in 3 listening spots and took average. Expected SPL level = 75dB.
Please take a note that room is very small (2,5m x 3m) and doesn't have any acoustic treatment.
Measure 1 - Only SVS subwoofer is connected, crossover set to 200Hz (on subwoofer itself for Argon and Gato and on amplifier only for WiiM Amp):
Most linear bass is on Gato followed by Argon. Wiim seems to have a lot of spikes even far below crossover frequency.
Measure 2 - Only SVS subwoofer is connected, crossover set to 80Hz (on subwoofer itself for Argon and Gato and on amplifier only for WiiM Amp):
Again Wiim seem to provide worst bass response. I don't understand why since subwoofer is fully active.
Measure 3 - Only Dali speakers are connected, no subwoofer, no crossover, left speaker:
Very similar measurement for all amplifiers, wow (seems Wiim doesn't have any issues in driving Dali Oberon 1).
Measure 4 - Only Dali speakers are connected, no subwoofer, no crossover, right speaker:
Again very similar measurement for all amplifiers, wow.
Measure 5 - Dali speakers and SVS subwoofer are connected, crossover set to 80Hz, left speaker:
Here we can see how much high pass filter is helping in bass management - the most linear is on Wiim. Interesting that Gato is not as bad as Argon even it doesn't provide high pass filter.
Measure 6 - Dali speakers and SVS subwoofer are connected, crossover set to 80Hz, right speaker:
Here I don't understand why there is so much drop in 60-100Hz range for WiiM. For Argon and Gato measurements are very similar to left speaker.
Anyway it seems that WiiM doesn't have any issues in driving Dali Oberon 1 speakers itself. The only questionable thing for me is subwoofer output - why there are so much spikes with subwoofer alone especially with crossover 200Hz. Especially 60-80Hz range seems to be problematic for WiiM in subwoofer output.
I'm really suprised how well it performed against much more expensive Gato amplifier in speakers alone setup.
For now I decided to return Argon amp and keep the WiiM Amp instead.
I'm also thinking about ordering Bluesound Powernode Edge to see if it will also have frequency drops in 60-80Hz in subwoofer output.
Frankly speaking placements were now 100% same but very close to each other (I just put the microphone on a chair but it might always move 1cm in any direction).Was your measurement microphone fixed in place for all subwoofer measurements?
Variable placement could easily explain the measured differences.
Depends on how your subwoofer handles LFE Mono vs Stereo Pre input.And it seems the issue is on WiiM side since it doesn't happen for both Gato and Argon amps. They also do use different connection type for subwoofer (single RCA in WiiM and double pre-out RCA in Gato and Argon). But that shouldn't make any difference, right?
Yep! I have and use it daily but it sounds lean to compared to other amps I haveSince I am a very satisfied user of streamers from the WiiM family (they replaced the Raspberry pi in my house), so I bought a bargain WiiM Amp. I wanted to use it in the bedroom. From the functional side, it is a fantastic device. Unfortunately, from the sound side, it is a failure for me. As a gadgeteer, I have a great many amplifiers at home from Class AB to the Class D amplifiers I use most often, including those based on the TPA3255 chip. Unfortunately, subjectively the WiiM Amp sounds the worst. Therefore, I suggest that those intending to purchase an amplifier from the WiiM family should wait for the unveiling of a new device from PFFB.
You can manually set sub level, delay, phase, and HPF/LPF frequency.I'm wondering if correcting for the sub might be a much more cost effective solution, given the low price of the Wiim amp, assuming that it can implement time delay between mains and sub.
More than likely either plain old perceptive bias - or comparing with a non transparent previous amp that the listeners ears have just got used to.I'm finding the complaints about sound quality rather odd. There's nothing in the review that suggests this should be anything but transparent. Unless you're driving some inefficient speakers at very loud volumes, I doubt 60W/8Ohm and 120W/4Ohm is terribly limiting.
Certainly this makes no sense - amps don't impact room reverb unless they are putting out more energy at the reverberating frequency. So either a previous amp had a lack in this area that the wiim is now filling with a flat FR, or the mentioned EQ adjustments (eg turning up bass) is causing it.he amount of room reverb that was not there before is quite impressive (in a bad way). No adjustment in the EQ solves this.
Agh, just realised it only has 1 line input. I have 3 devices, though seems like the Amp makes the Pro plus redundant, though it's DAC is not as good, but I have a phono amp to connect and a tuner! I mean I could survive with swapping things over but what a faff.You can manually set sub level, delay, phase, and HPF/LPF frequency.
Afaik the WiiM Amp does not support automatic sub integration.
The WiiM Ultra has Line in, Phono in (built-in Phono pre), and Sub out.Agh, just realised it only has 1 line input. I have 3 devices, though seems like the Amp makes the Pro plus redundant, though it's DAC is not as good, but I have a phono amp to connect and a tuner! I mean I could survive with swapping things over but what a faff.
So that I'm clear, Amp has a digital preamp including sub for DSP, Ultra does the same but with more inputs and a better DAC. Obviously it doesn't have the analogue output stage, but then you'd output the Ultra into a Line in on say my Yamaha 501 in the same way I connect the Pro Plus, the difference being that the sub is included in the DSP of the Ultra.The WiiM Ultra has Line in, Phono in (built-in Phono pre), and Sub out.
But you'd have to add an external Amp.
Correct!So that I'm clear, Amp has a digital preamp including sub for DSP, Ultra does the same but with more inputs and a better DAC. Obviously it doesn't have the analogue output stage, but then you'd output the Ultra into a Line in on say my Yamaha 501 in the same way I connect the Pro Plus, the difference being that the sub is included in the DSP of the Ultra.
I don't know.How good is the phono section?
A remote control is included.Checking specs on Wiim site, no mention of RC, but presumably same functionality as the pro plus?
