Wifi VS Ethernet for streaming quality
The audiophile router with dampened chassis and liquid nitrogen cooling surely has to be a thing
Seriously off topic here...
Liquid nitrogen is certainly cheaper than liquid helium. But both can suffocate people...
I worked for a month at an environmental test facility outside of Boston. They were very careful to warn me not to enter a chamber where nitrogen had been used for cooling until the enclosure was flushed with air, as a couple engineers had died a couple months earlier doing that.
Back on-topic:
Uncompressed Red Book PCM (44.1Khz x 16 bit) uses about 10 MByte/minute.
24 bit vs 16 bit is aa additional x1.5 factor.
96KHz is an additional x2.16 factor.
So 96Kx24 bit maxes out around 32.4 MByte/minute.
(for stereo).
If the internet is crappy enough, it could be problematic I guess. But probably not due to wifi (unless local area interference is excessive); it seems likely more of an ISP issue.
Latency indeed matters not a whit for home recreational playback only, so long as all the channels are arriving together.
With gaming and mixing/monitoring live music, it can very much matter.
For lip sync in video, the solution is play using software where the video can be delayed to match the soundtrack
if the delay is constant.
Interesting. I'm curious of use cases where the audio channels (for a home playback system) would be arriving via separate ethernet streams / connections (whether Wi-Fi or wired).
For lip sync in video, the solution is play using software where the video can be delayed to match the soundtrack if the delay is constant.
Similar question on this. The usual case would be a delay issue when video and audio are routed separately through an AVR system; but that is usually HDMI and S/PDIF or analog interconnects. I'm trying to imagine a home audio playback case where the lip-synched video and the audio tracks are being sent separately over an ethernet (Wi-Fi or wired) connection.
My statements were clarifying the latency issue more generally.
But I was researching using multiple distributed DSP nodes in a system using different AoIP protocols, say 8ch per RPi5 unit. Keeping clocks sync'ing, both system level and the AD/DA conversions is a serious challenge to keep phase alignments.
Similar answer, was not talking about network protocols, more of a general solution.
Personally I have zero interest in most industry standard AV gear, and all my shows and films are played from DL files, where the audio gets piped into my music rig, no networking involved but lots of high latency conversions, upmixing and other DSPing.
TBH I would not put audio signals over wireless, although I do enable such for my kids' convenience, letting them tap into my systems using their screen devices. They seem to be uninterested in SQ anyway, when I offer audiophile gifts they always ask for cash equivalent instead, use my credit to upgrade their iFruit gear
Bad equipment is bad equipment. That has nothing to do with data transmission speeds and variations (jitter) of wired vs. wireless on a sufficiently adequate network.
...Your writing is bizarre, obtuse, and jumps all over the place. I still do not see any clear argument of fact in what you are writing, so I'm simply reacting to the unsupported "facts" you are tossing around.
But is that relevant? Except for synchronized live music recording from multiple source or first-person real time gaming, why does such latency variation matter? Devices have been dealing with latency and jitter (latency variation) for decades now. A simple buffer (with slight delay in playback to allow the buffer to fill up) addresses those issues. Unless, of course, you are using poorly implemented devices (as you said you were using above) or an inadequate network.
Now, drop outs (lost data) is a real issue if you are using a protocol that does not include re-transmit (i.e., UDP). But if your network is routinely dropping packets, then that is a factor that must be addressed in your network. A competently implemented Wi-Fi or wired network will not face that issue; and a high audio quality stream will address lost packets as part of its protocol process.
This seems to me to be a very stupid statement. Either your network is delivering the packets (within acceptable latency relative to buffering on the device) or it is not — either there is packet loss (i.e. missing bits of digitized sound) or there is not. Echo, reverberation female vocal treble, snare drum transients, etc. will all be there if the data stream is correct; and all of them will be adversely affected if it is not.
Sorry, but BS really isn't what ASR is about. Facts are welcome, BS opinions are not.
So do I
. In fact, as part of searching for a rental house, a major factor for me is whether or not I could easily implement wired ethernet between various places in the house, and run it all back to the WAN-side router. And I also run multiple VLANs for: my work-related data, our home data, IoT devices, VoIP devices, and also an external guest DMZ.
But you know what: I do that out of preference, knowing full well that I can equally create a WiFi mesh that will fully cover 100% of my needs. I strongly prefer wired; but that doesn't mean wireless is not sufficient for what I need. Which is why — as a dyed-in-the-wool wired-head — I'm calling BS on your rant. Oh wait, I also have a WiFi mesh (Ubiquity AC Pros) that is fully integrated into my VLANS for devices that are wireless-native (e.g., iPhone, tablets, etc.). I wire where I can; and I don't where I can't. But I know full well that wired and wireless are both more than sufficient.
You still have not explained why your so-called pitfalls are a real problem for your situation or anyone else's (outside of using poorly designed hardware).
I am going to ignore your grungy, childish personal attacks, and illustrate you an example, besides the answer you've already provided to your own rhetorical question:
Starting with "Bad equipment is bad equipment"
Before the days of mesh WiFi becoming robust, I ran a whole-house, multi-zone audio system — four zones, simultaneous or independent — off an Integra pre/pro, later replaced by a Rotel RSP-1576.
The backbone is Dante over PoE — dongles, controllers, the works — running on a fully Cat6-wired, 10Gbps LAN that also handles 4K video and NAS traffic. Dante uses IEEE 1588 PTP for clock sync across every device on the network, spec'd to <1ms latency, and by design it won't pass audio over WiFi at all — the Dante endpoint hardware itself has no wireless radio for the audio path, and Audinate's own Virtual Soundcard and Via applications explicitly refuse to recognize a wireless interface for audio, even on a PC that has one. (Dante Controller, by contrast, can run over WiFi — but it's a config/monitoring tool, not part of the audio path itself.) WiFi does have its own native clock function (TSF), but it was built for MAC-layer housekeeping, not audio-grade sync — which is a big part of why this stays wired. (you may investigate Sonos patents for this discussion).
When I first brought a Dante xmt/rcv pair online to the upstairs serverPC, I could hear an audible delay between the downstairs HTPC system and the upstairs one — walking between floors, and sitting in front of the server PC. I initially suspected the Dante link. It turned out to be processing latency in the Rotel itself, not the network.
The point isn't "Dante was blameless" — it's that a wired, PTP-synchronized network allowed me to isolate the actual source of a sub-frame-level delay down to a single component, cleanly, with hard data. That's the diagnostic headroom my deterministic network provides. I don't know how you'd chase the same fault through WiFi's non-deterministic jitter, where the variance itself becomes a confound on top of whatever the connected hardware is doing.
Everything in the house is already Cat6, PoE, and 10Gbps on the LAN side, feeding 4K video and NAS traffic in addition to audio — all independent of the router/modem. I have no real need for more wireless gear — not because WiFi can't stream music adequately for casual listening, but because it adds a variable I don't need in a network that already works.
I must have a dozen WiFi (one w/IEEE 802.11be) and half-a-dozen Bluetooth-capable devices… unfortunately, never had the inclination (or any need) to make use of them.
Please try your hardest NOT to insult me any further. ty.
(for stereo).
~4Mbit/s (the more intuitive network load of the above figure) is a completely negligible load on any even remotely modern home network. Zero issues should result, even at 24/192. My ISP connection is 1Gbit/s at $65/month. My home network is 2.5G. Audio is a laughably undemanding app these days.
Latency and jitter matter zero for music playback in a home network. The protocol stack takes care of it. It's highly unlikely anyone will encounter buffer starvation these days, which is the only thing you have to worry about in any multimedia stream... and is unlikely to ever happen with apps as undemanding as audio these days. If you're a hardcore gamer (I have never been) things may be somewhat different - but those requirements wouldn't make your audio "better" in any way, ever.
With respect to Wi-Fi, radio interference from other devices in the home in the 2.4GHz band is the obvious one (Microwave ovens, cordless phones, baby monitors, etc.) Another one is momentary electrical noise from devices (especially those with motors or compressors in them). For example, turning on the extraction hood causes the Amazon Echo in my Kitchen to stop streaming the radio for a couple of seconds - It's not a big issue, but it's one that I'd rather I didn't have (and probably wouldn't have if I could plug Ethernet into the Echo).
I do agree that a well setup WLAN will be sufficient for 99% of audio use cases, but that 99% is uninteresting, it's much more fun to talk about the other 1% :)
2.4GHz-only routers are hopelessly obsolete, not just performance but security (because 2.4 travels much farther and yet the routers supporting just that band are 25 years old).
And let's repeat: noise on Ethernet or WiFi does NEVER impact the actual payload. A packet either arrives or it doesn't, and if it arrives it means its payload is bit-perfect and buffering will take care of any timing concerns.
Modern networks are way -waaaaaaaaayyyyy- beyond the needs of audio. Don't overthink network issues. They will never ever corrupt audio -or any- payloads and their performance is vastly superior to what's needed for the use case. If military and healthcare and financial apps are perfectly served by today's networks, it's silly for us audio nerds to worry about that aspect.
One of my favorite WindowsOS network traffic-monitoring tools has been the hageltech DUmeter... going all the way back to the Win98 days.
Two questions about “How to improve audio performance, employing WiFi (pre v.6E)?" << via {CLAUDE} >> answers in 2 parts:
Part #1:
{CLAUDE} >> Good, solid technical ground here across several real sources — let me organize these into what's actually actionable in Windows 11, since this overlaps directly with what we've been discussing (power-saving throttling is the single biggest recurring culprit across every source).
1. Stop Windows from power-throttling the WiFi radio — the single most impactful fix, and well-documented. Multiple independent sources describe the same failure mode: when Windows switches a power plan from High Performance to Balanced/Power Saver, it can force the WiFi adapter into a lower power state, creating latency spikes from under 10ms to over 500ms — exactly the kind of instantaneous jitter spike that breaks a playback buffer. Two separate settings control this:
• Settings > Network & Internet > Wi-Fi > Hardware Properties — disable "Use network stack for power efficiency."
• Device Manager > Network adapters > [your WiFi adapter] > Power Management tab — uncheck "Allow the computer to turn off this device to save power."
2. Set your power plan to High Performance, system-wide, not just for the WiFi adapter. Several sources flag the same pattern independently — a "Presonus Audio Streaming" power profile unexpectedly reverting to Balanced is cited as a real-world cause of DPC latency spikes in one forum thread. Control Panel > Power Options > set to High Performance (or your audio interface vendor's dedicated power plan, if one got installed and silently switched away from).
3. WiFi and Bluetooth drivers are a documented, specific DPC latency culprit — worth checking even if you don't use them. One forum thread on audio buzzing/latency states plainly: DPC latency is generally caused by drivers for onboard hardware, and network — especially WiFi and Bluetooth — drivers are common offenders, to the point where it's quite common to disable WiFi and Bluetooth in BIOS entirely to get stable DPC latency for audio streaming. This is low-cost: Device Manager, and if truly unused, disabling the radios in BIOS removes a documented source of DPC latency interference from other audio work on that machine, even though it's not the stream itself.
4. Check DPC latency directly rather than guessing. Multiple sources reference a free diagnostic tool (LatencyMon, cited in the inMusic/Presonus troubleshooting doc) that flags exactly which driver is causing spikes — "at least one detected problem appears to be network related... try disabling [the WLAN adapter] to get better results" was literally the tool's own recommendation in one case. Worth running once to get a concrete before/after reading rather than tuning settings blind.
5. Windows network reset as a troubleshooting reset-button. One Windows 11 25H2 user reported fixing "weird network behavior" repeatedly just by using Settings' built-in network reset option, which resets all adapters to default — worth keeping in your back pocket if something that was working degrades unexplainably, which happened in that same thread's exact scenario (LAN audio streaming that "was working beautifully, now it's not").
On your WiFi-generation caveat specifically — all five of the above are generation-agnostic; they're Windows/driver-stack issues, not WiFi-6E-specific optimizations, so they apply the same whether you're on 802.11ac, ax, or be. The one thing I'd flag as not relevant to your situation: roaming-aggressiveness tuning and band-steering settings (6GHz-specific stuff) are aimed at multi-AP mesh/roaming scenarios — since you've told me repeatedly you're fully wired and have no real WiFi audio use case, none of that applies to you; it's purely for anyone actually trying to stream audio over WiFi, not for your own setup.
Part #2:
{CLAUDE} >> Router/network-side (these matter more than client-side tweaks, honestly):
• WMM (WiFi Multimedia / 802.11e QoS) — nearly all modern routers have this enabled by default, but worth confirming; it prioritizes audio/video traffic classes over bulk data at the MAC layer, reducing contention-driven jitter specifically for streaming traffic.
• DSCP/QoS tagging and router-level traffic prioritization — several sources flagged this directly; setting your router's QoS to prioritize the audio-streaming device's traffic (by device, port, or DSCP tag) reduces the chance other household traffic (someone's 4K Netflix stream, a big download) steals airtime mid-playback.
• Dedicated band/channel for the audio device — putting a WiFi audio endpoint on the 5GHz or 6GHz band specifically (less contested than 2.4GHz, which every smart-home gadget, microwave, and neighbor's network also crowds) meaningfully reduces collision-driven jitter.
• Fixed channel width and manual channel selection instead of auto — auto-channel-selection can trigger mid-stream channel changes under interference, which is audible as a dropout; locking it down trades some peak throughput for consistency, which is exactly the tradeoff that matters for audio.
• Mesh backhaul matters a lot if a mesh system is involved — wireless-backhaul mesh nodes (where the node-to-node hop itself is also over WiFi) stack latency and jitter on top of the client hop; a wired-backhaul mesh (nodes connected to each other via Ethernet, only the final hop to the device is wireless) is a meaningfully different and much more consistent animal than an all-wireless mesh.
Client-side (Windows 11), beyond what I listed last time [
in part #1]:
• Disable adapter power-saving (already covered) — this remains the single highest-impact fix, since the 10ms→500ms spike documented earlier is squarely a jitter-and-dropout cause, not just a throughput issue.
• MMCSS (Multimedia Class Scheduler Service) — Windows has a built-in service specifically meant to prioritize real-time audio/video threads for low, consistent latency; it's on by default, but the NetworkThrottlingIndex registry value (under HKLM\SYSTEM\CurrentControlSet\Services\Multimedia\SystemProfile) by default throttles non-multimedia network traffic to protect multimedia playback — leaving it at default or confirming it's not disabled is relevant specifically for streaming-audio consistency.
• Buffer/latency settings in the playback app itself — this is really where "fixing" WiFi jitter actually happens in practice, [
as opposed to the Dante's own approach]: a larger client-side buffer trades a bit of fixed startup delay for absorbing variable network jitter. Most consumer WiFi audio systems (Sonos, AirPlay, etc.) already do this invisibly; DIY setups (like the Mintlify doc's WASAPI loopback / virtual-audio-cable approach) expose it explicitly, with presets literally labeled things like "WiFi (Poor)" that widen the buffer specifically to compensate.
• Exclusive Mode / disable Windows audio enhancements on the playback device — reduces OS-level processing overhead/variability in the audio pipeline itself, which is a separate (non-network) source of inconsistency that can compound with WiFi jitter rather than cause it.
Every one of these is exactly the kind of "competent implementation"— QoS, dedicated bands, wired mesh backhaul, buffer sizing, power-management fixes — none of it changes the underlying physics (contention-based medium access is still non-deterministic), it just manages the consequences well enough that a properly tuned WiFi setup can deliver consistent single-stream casual listening. ...
Unfortunately, these potential settings still wouldn't get you Dante's deterministic multi-device sync — none of these techniques touch that fundamental gap — but for the "is WiFi good enough for normal home audio" question, this is the actual toolkit that makes the "yes, if competently implemented" side of his argument correct for that narrower claim.
...as always ymmv ;)
Agreed that there are some environments where Wi-Fi will lose packets due to interference; which wired protects against. But as noted, those are not the typical situation (anymore); and there are mechanisms that can improve the network coverage in those areas.
And equally, there are many devices (not just wireless access points) that are still stuck on 2.4 as the only Wifi option — e.g., all of my squeezeboxes.
At the core though, we are saying the same thing: there is no reason why Wi-Fi isn't more than adequate except for a few cases. Nonetheless, I'm a wired-head whenever I can get away with it... but I know that my environment would still work just as well on Wi-Fi. (That said, I'll pay more attention next time I'm upgraded the vent hood)
... but for the "is WiFi good enough for normal home audio" question, this is the actual toolkit that makes the "yes, if competently implemented" side of his argument correct for that narrower claim.
Thank you.
Thank you.
For what?
I wouldn't bend an ear for you, unless that is your way of apologizing for insults and for intentionally ignoring the following part of my original post:
....Afterall, this is ASR and snuffing-out opposing/dissenting views of a 'new-wireless world'... by calling such technical issues BS and calling those who prefer to stay wired old farts, is NOT in the benefit of anyone.
Of course, we can go on the argument that anything better than Red-Book is BS but then again we seem to lavish a few dB deeper noise floor, like it really mattered in a Red-Book world and the rest is BS and bits-are-bits....
1. In terms of sound quality - the effect of the transmission method on the perceived fidelity of the musical reproduction - WiFi and ethernet are of course identical because their impact on sound quality is nil.
2. In terms of robustness - resistance to transmission issues that can cause audible glitches that are clearly not part of the musical source - WiFi and ethernet are both more than capable of handling the bitrate of even the most high sample-rate digital source. In practice I've found ethernet more reliable in the past, but it's been several years since I even attempted to use WiFi as the transmission method in my main system. Using WiFi from my and family members' phones to Airplay speakers these days, it seems to be rock-solid. But we don't even need to argue about whether WiFi is as robust as (or more robust than) ethernet. If someone has a dodgy WiFi situation - because of outdated WiFi gear, an unusually tough setting/environment for WiFi, or some other reason - they will hear audio glitches or dropouts. It's not like alleged differences in soundstage or "rhythm and pacing" - there are audible glitches or there aren't - it's not subtle. Most of us won't have any such glitches with WiFi. Those few who might can either troubleshoot, upgrade their network equipment, or stick with ethernet.
But of course, don't let the above stop you from arguing about WiFi if you're enjoying yourself. :)
but but when i use my synergistic liquid placebo optimized ethernet cables it's like a veil is lifted from the music and Steely Dan and Dire Straits are right next to my earholes giving me shoulder rubs and telling me that I have good taste in music
Good thing that is all they are doing... if it was some other performer than Steely Dan or Dire Straits, you might find yourself in an indecent situation (at least, one that should not be shared on ASR since this is family-friendly forum) :cool:
Oh, right - I forgot about the synergistic liquid placebo cables. :)
