Wifi VS Ethernet for streaming quality
In theory. In practice often not so unless you're in pretty close proximity with clear LoS to the access point, have the requisite amount of antenna diversity, and have a decently clear channel of sufficient size. Plus, any halfway competent install of cat5e can easily support 2.5Gb ethernet. Even 5Gb is a good bet as long as the cable run isn't too long.
Yes agreed. If WiFi reception isn't perfect you won't get the fastest theoretical speed. And fastest speed depends on antenna capabilities at both ends. But still fairly possible to exceed 1gbps with WiFi these days.
Of course wired connections can support faster speeds (i.e. for a PC with a network card, and hopefully you have at least 2.5G or 10G wired to your APs) but on most TVs, Blu-Ray players, games consoles etc the socket will be 1gbps max.
(1gbps is perfectly adequate for those uses).
I live in an apartment building surrounded by other apartment buildings (a row of brownstone townhouses in New York City) and suffer frequent wifi streaming cut outs on my Denon 3700. Running an ethernet cable would be a major pain due to the logistics. It is super frustrating.
My best hypothesis is it's due to nearby network traffic. Damn guy working from home downstairs must be transferring massive documents!
It is getting to the point that devices may get a faster connection via WiFi than via their wired socket. Typical wired sockets only go to 1gbps, which WiFi 6 can exceed.
The song still takes 3:05 minutes to play, no matter how fast it downloads.
Almost certainly not just the one guy, apartments buildings are a worst-case scenario. Likely at least a dozen, if not more, devices all competing for airtime in the 5GHz band. You could try going to all your neighbors and asking them to turn down the transmit power on their wi-fi routers (and receive mostly blank stares in response likely). Have you considered trying powerline ethernet adapters such as these?
For better listening I prefer BluRay audio in ATMOS, SACD 5.1 or CDs all in physical media, otherwise streaming is good enough to my ears!
Optic fiber with 1GB and never any problems
You talk about airwave pollution and seriously suggest polluting power lines instead? Really? :p
I'm aware that the speed of connection is these days basically irrelevant for audio streaming.
I was mostly making the point that whilst previously it was always the norm that if a device offered both WiFi and wired connections, the wired connection would be faster. Now we have reached an inflection point where for some devices on the market their WiFi connection may offer the higher maximum theoretical connection speed. (I find that point interesting).
(Although WiFi still has lower reliability and its real world speeds will probably be further below the theoretical max, as has been discussed).
Audio is at the most low single-digit mbit/s range, most typically around ~1 mbit/s if lossless compressed or ~0.256mbit/s if lossy.
Most home internet lines are capable of hundreds of mbit/s now, with gigabit increasingly available in the West. both wifi and ethernet can easy do hundreds of mbit/s to even gbit/s range.
Audio just doesn’t use very much bandwidth in the context of internet and home networking - both wifi and ethernet should be able to comfortably handle 100x the bandwidth required. If reliability of your wifi is an issue, then that is its own problem unrelated to what it is you’re streaming. Either your music packets will be delivered or they won’t - this isn’t like analogue where they’ll be somehow worsened by the medium in which they got to you.
Is that true when you have 5 kids and there play friends, as well as your significant other and her book club girl friends all using the WiFi at once? Or just if you are a single person using the WiFi?
That definitely looks worth a try, thanks for the suggestion!
And you're totally right that it isn't just one culprit. My guess is I'm the only dinosaur in my building (forget those surrounding) that even has a single device actually plugged in! And that's just my desktop pc.
I would have to disagree with that a bit. RF is a limited resource. The airtime should be conserved for things that actually need it, not for things that don't generally move and could easily be wired in. The 5GHz band is already a congested mess in any populated area, the only saving grace for indoor use is that walls are pretty effective at attenuating it. When I'm trying to do outdoor PtP or PtMP links, 5GHz has become a nightmare due to the number of devices screaming out in that band on 80MHz or even 160MHz channels these days. Pretty much impossible to find a clear channel in any remotely populated area.
My RS180 & RS220 Sennheiser headphones are not Bluetooth but auto operate on either 2.4 or 5.0 cordless phone frequencies.
These days (they pick the band and frequency automatically) I have about 30 meters of freedom & & out of my house.
It's my understanding that Bluetooth has a lot less range.
I can be riding my lawn mower, listening to music from my home stereo.
On the other hand, with the right antenna and correct placement of the antenna and a 2 watt WIFI transceiver at each end it's possible to do 60 miles (or more) of WIFI.
6E/7 wifi routers are amazing. Can't imagine using ethernet throughout the home anymore. That's a thing of the past like winter grass installation during drought water restrictions. The need for ethernet in normal single family residences is less each year.
Turn of the century townhouse with plaster lathe walls in Brooklyn - I can barely connect to my neighbor's wifi just on the other side of a shared wall. 5ghz band crowding is sorta moot here. Mesh networks are suboptimal so anyone who cares about network quality needs ethernet - at least to the individual floors. I ended up geeking out and installing a Ubiquiti-based network - the Apple (solid but closed ecosystem) of networking equipment. But now Roon can group devices on all 3 floors.
This is how much an uncompressed PCM at 44.1 KHz streams through my laptop into an endpoint in realtime using Ethernet:
If your WiFi isn't congested, it should handle realtime streaming without any dropouts whatsoever
So, to summarize, distinguishing digital dropout as "reliability" separate from "audio quality"
It will be a very rare circumstance for many that you are certain your wireless infrastructure won't ever get bogged down enough to cause digital dropouts, circumstances do change beyond just transient high congestion issues.
IF you are lucky enough to have the necessary resources to actually ensure that certainty, then no worries you can agree with OP.
Otherwise, you will get greater certainty of "no worries" by routing some Cat6a (or 8) wires.
For those that literally can't do that, or consider the cost/effort not worth the trouble to get that greater certainty, then they should work on climbing the learning curve and maybe spending a bit less to find one of the many "middle ground" solutions.
Or just decide to accept that bit of extra uncertainty, many if not most people just don't seek optimization in this topic domain.
And uncompressed PCM is a worst-case. Here's me streaming a 24-bit, 48kHz FLAC from my NAS:
Tidal has some interesting behavior, though thinking about it this is probably the strategy most streaming services use to help avoid interruptions. Instead of a constant stream, it sends the data in short bursts that typically top out at around 8.5Mbps:
100% what @john61ct wrote. But a minor quibble: you can just as easily use Cat5e or regular Cat6 cables for routers at 1Gbps speeds, provided you are not trying to run it at 30m to 100m+ distance.
And further, you can use Cat5 cables if the ethernet port on your end device is 100 Mpbs rather than 1 Gpbs.
And as demonstrated by graphs from @kyuu and @majingotan, you can even use Cat3 cables if your end device is only 10 Mpbs rated... assuming your modern router or switch can still go that low. :cool:
Sure, even with 10-15 people home as long as each floor/room has decent reception there’s certainly enough bandwidth to go around.
In the RTINGS review of my router the slowest interior speed observed was 204 mbps, while congestion would hurt efficiency some, that is an area the latest wifi standards have improved a lot.
Even on a separate floor from router I measure 382Mbps download and 114Mbps upload Wifi speeds.
Qobuz supports uninterrupted 192kHz streaming with 25Mbps connection and will likely use less than 10Mbps.
In addition, I typically purchase the music I enjoy and install it on RPi-5 Moode USB drive which requires no internet connection at all. The need for a ethernet cable in this setup is zero. :cool:
1 floor Ranch Style home is mist common here (some times a hallway like a bowling lane wit 5 bedrooms).
But, in my case, no cell phone signal gets here. (Nor do I want it to). The nearest neighbor is a 1/2 mile away. Since the area is now protected from any more structures being built on both a state and federal level, it's not likely to change anytime soon. I am the last place on the power grid and get 30 amps of service.
But the benefits are HUGE (Hunting, fishing and trapping provides supermarketless food, farmers markets provide the rest):
And limited access keeps the riff raff away:
