Thanks to all the great content here and elsewhere, I'm gaining a better understanding how rooms affect sound (and how speakers are NOT MAGICAL ). And with the realization that reflected sound has such a big role (along with all the literature debating its absorption / diffusion etc), I was curious what happens if I got rid of the direct sound. So I flipped my speakers around.
And it actually doesn't sound too bad! I'm digging the 'bigger' sound, like my speakers are now at the walls, although yes, the highs are definitely reduced. Imaging is probably reduced too, but that's pretty hard to measure and the speaker placement is already bad, so....
First, my small untreated, not-to-scale room and a 2.1 setup (KEF 3005se + Definitive Tech sub).
Typical front facing speakers vs the flipped speakers, measured at sitting position.
Note that there's already EQ applied for up to 200hz.
The beginning of the high frequency dropoff is so precise at around 1.2khz. Or maybe it's further impacted by my monitor. My noise floor can be quite high, so I do boost my bass. After some trial and error, these are my EQ settings, with a 4db, 1.5khz high shelf filter boost for the lost high end.
The 4db boosted result (highlighted in yellow)
And this is after dropping all eq filters by -4db (from my understanding that boosting is generally not good for speaker longevity).
Sure, there are still some issues like in the 350hz region and the dip at 165hz, but the result is still very listenable compared to just the conventional front facing position. I'd like to believe now the sound is more 'airy' But the nice thing is now I have a convincing illusion (to my ears) that there's an actual band / singer right behind my monitor. In a small room. The speakers disappeared!
It has been an interesting experiment. I'm still listening to my music in this position and figuring out what to tweak along the way. Obviously for people who have their speakers right against the wall the result might not be so good.
My conclusion is it's important to understand the concepts, but also not to be too limited by what are best practices. When consuming music at least.
