www.audiosciencereview.com
Thanks, but I don't understand the measurements and how to compare the cartridges.Take a look at the cartridge library:
Introducing the Phono Cartridge Measurement Library
Skip to the index. After years of development we are finally launching our phono cartridge measurement library. These measurements were created using the brilliant cartridge response python script, SJPlot, written by the legendary @scott wurcer and @JP. Information about its origins can be...www.audiosciencereview.com
You can set the search window to "This thread" to search the entire thread for a specific model:
Thanks for your explanations, so yes, I am looking for a cartridge in this brand because I can order AT brand.Wrong question Mister, The turntable you have is irrelevant for choosing stylus, what cartridge shall she stylus fit inn to? that determines the stylus options.
The styli you list are not compatible with the same cartridge body. They fit into THREE different bodies and are not interchangeable
Or are you looking for a cartridge...?
Excellent link, thanks! Now I can decide wich one!The VM95E has an elliptical stylus and according to tech reviews, takes the older AT95E a stage further.
You'll need a translator, but the VM95 family is reviewed here -
Familientest Audio-Technica VM95: 5 MM-Abtaster unter 200 Euro - LowBeats
Nicht einen, nein, gleich fünf neue MM-Tonabnehmer bringt Audio-Technica in den Markt. Die gemeinsamwww.lowbeats.de
of the ones you mention, the VM95E is the 'best' I feel - you have to all but double the price to get anything I'd personally regard as 'better.' The VM95 body has a range of styli available and a well liked one around these parts is the VM95ML stylus, easily fitted later on. The 95SH (Shibata tip) is a touch more refined perhaps, but the ML seems to find huge favour here.
Frequency response should be a perfectly flat, horizontal line.Thanks, but I don't understand the measurements and how to compare the cartridges.
Interesting. To these ears, the big step up is between the E and the EN (the space really opens up), which would seem to correlate with the IMD measurements. This is surprisingly obvious. If I ever decide to properly refurbish my "project" Grundig PS 4500 that's been gathering dust since about 2010 and go for a new cartridge instead of using my NOS ATN71E, I guess VM95EN/ML/SH would be some hot candidates. The Ortofon 2M Blue and Black samples also left a good impression, but the latter would definitely be too spendy for my tastes.![]()
For MM cartridges there is often a peak at high frequencies that varies with the load. This is why more expensive phono amps often include adjustable loading, allowing the load to be adjusted to give a flatter response.Frequency response should be a perfectly flat, horizontal line.
AT95E cartridge need ATN-95E,, AT95E and VM95 are very similar but not interchangeable, 95 is the old type VM95 the new
This is what I read before and thanks for confirming that.Actually that's not quite correct. It only works one way, though. I.e., the newer AT-VM95 family needles also fit onto the older AT93/95E(B, X, /Pro)/340x/341x/345x bodies no problemo. Whereas the other way around it doesn't work without plastic surgery, as the downwards sloping side walls of the mounting frame of the AT-VM95 family bodies go too far down to not collide with not correspondingly shaped the side walls of the older needles.
Greetings from Munich!
Manfred / lini
Is CBS STR100 the one to get? Want to avoid rare and $$ disks.Be aware of the test records used in ^ video. That Ortofon is a poor choice for frequency response.
