I didn't see where the AOR said class AB sounded better than class D. What I read was for the "price point" they could get AB with better sinad than D. Using with the tweeter might have more to do with hiss.
I doubt they build any amp themselves which is not bad though since they are a loudspeaker company and its better to use external expertise in fields you are not long into.On the other hand, if you are more of a skeptical mind and know KEF and their hyped products for decades, you may guess that they are simply not able to build a decend Class D amp for driving a tweeter.
Many studio monitors use similar designs (ADAM, for instance). This could have something to do with tweeter hiss, but competently designed speakers don't hiss even with PWM amps.Focal monitors use class G for the LF and AB for the HF.
The features left out of the LSX II LT, if removed from the LS 60, would probably reduce the price of an LS60 LT by the same amount. But that is a much lower percentage of the LS60 cost: so unlikely to sell in greater numbers as the LSX II LT might/should.As to why the AB amp isn't in the LSX range - they are powered according to the description, not active, so that would be a single class D amp?If it's more cost effective then why isn't it used in the KEF LSX range? Why would you think a profit making company designs products based exclusively on engineering decisions? Maybe they used AB in this context as a marketing ploy aimed at audiophiles wedded to "AB is better"? There's an interesting split in the KEF LSX range with the KEF LSX II LT aimed at the non-audiophile streamer, and the KEF LSX II aimed at audiophile types (Roon capability, aux input for turntable, etc.,...) One wonders if KEF might introduce an LS60 LTD at a much lower price point?
Would you ever except to even see the word in a Purifi specsheet?biwire
Missed that, which is a much bigger difference. Thanks. It makes an LS60LT even less of a value proposition I guess.The LSX II has amps in each speaker and can be used wireless connection in the KSX II LT amps are only in one speaker with a usb c connection to secondary they aren't wireless.
I hope that at some point, KEF releases a renewed version of the LSX with 12th generation UniQ and metamaterial.The features left out of the LSX II LT, if removed from the LS 60, would probably reduce the price of an LS60 LT by the same amount. But that is a much lower percentage of the LS60 cost: so unlikely to sell in greater numbers as the LSX II LT might/should.As to why the AB amp isn't in the LSX range - they are powered according to the description, not active, so that would be a single class D amp?
I'll guess that one market driven decision is to make it flat up to 36kHz ? Excludes most class-D plate amps . But reels in the HiRez audio crowd .I would not be surprised if this was really marketing driven, given the likely inaudibility of the difference. But I’m not so familiar with the cost/performance curve for non-hypex class D, so could be legit as well.
No speaker company build their own amps,they are all of the self.
Here's one of what Genelec uses:
Tottaly of the self ones.
Look at the suggested applications
So?
You're right,I forgot about these ones and probably there's others too.ATC are building all their own class A/B amplifiers in-house. As far as I know almost all their active models use more or less the same circuit design as the P1 and P2 amps but with different amounts of power on hand.
On high enough level self noise of let's say bad class D one's with not so good SNR on path from tweeter's is audible even in far range setup. Given real content even 8 KHz is high enough regarding overtones and 12 KHz is certainly enough for almost anything.I would not be surprised if this was really marketing driven, given the likely inaudibility of the difference. But I’m not so familiar with the cost/performance curve for non-hypex class D, so could be legit as well.
Guessing isn't very scientific.KEF ... you may guess that they are simply not able to build a decend Class D amp for driving a tweeter.
So today, IMHO, pushing class-A/B for tweeters is more a marketing thing ("our customers expect tweeter amp to be A/B") than a technical one.
