Why using a DMM is very unreliable when calibrating level for A/B testing with class D amplifiers
So audio interface + REW and look at the fundamental
Originally posted here, but I find it important enough to open a new thread.
I would like to explain in deep why the usually recommended method of calibrating of level of the amp output with a 1kHz sine and DMM is unreliable in case f class D amplifiers.
I have tested BerryBak BVS2300 vs. SMSL A100, into 8ohm load. The former uses AD modulation, the later BD modulation, filter-less. Both types of modulation are explained here:
https://e2e.ti.com/cfs-file/__key/c...nts-files/6/Class_2D00_D-LC-Filter-Design.pdf
To put it short, both create a lot of unwanted HF noises, however the filter-less BD is much worse in this regard.
Let me start with oscilloscope shots from the BerryBak.
1kHz/1Vrms output, unfiltered
Please note the high 450kHz switching frequency residual superimposed on the 1kHz sine.
1kHz/1Vrms sine, filtered
Now the same, but 30kHz low pass filter is added at the oscilloscope input BNC connector. Still a small 450kHz spike is visible, but negligible.
Now we connect a DMM instead of the oscilloscope. The situation is like a blind man in the night. I have used two different DMMs, of quite a good quality.
1. UNI-T UT71B, with rated AC measuring bandwidth of 100kHz, in fact measuring even higher.
2. Protek 506, measuring reliably up to some 10kHz
Now, what happens if we connect them across the 8ohm load, instead of the oscilloscope. The chart below shows the results.
The faster UT71B shows similar readings as the oscilloscope and it must be used with the filter to give reliable readings. The slower Protek 506 seems to be less affected by switching residuals, but the readings are unreliable. Hopefully somehow consistent with the filter.
The conclusion is clear - using a filter is a must when calibrating class D amplifier levels for the A/B test, even with the DMMs.
Are you sure you both the scope and the DMM are measuring the same AC+DC or AC only? Also, your input to the Scope is single ended with a lousy CMRR, whereas most good DMM have a reasonable CMRR. Then there are the calibrations of both instruments to consider and lastly the scope front end is 25MHz wide, even at 30kHz the noise contribution can be significant. If you are doing high precision measurements you should estimate the noise power, by finding the equivalent noise bandwidth of your 30kHz filter and the noise floor in the band DC to say 50kHz.
The filter-less SMSL BD design can be related to the low cost and is the worst possible regarding HF and VHF emitted noise.
I don't dispute the main point of this thread: the output voltage of D amplifiers cannot be measured using a DMM. However, after extensive study and use of the MA12070, I can't say it's a definitively bad, low-cost solution. While the noise level of the DB is theoretically higher than that of a DA (Hypex and Purifi are examples), you shouldn't compare an expensive DA with a cheap DB. In reality, the noise level of amplifier DAs is usually no lower than that of the DB. However, the distortion level is significantly higher. There's also a lot to consider in the absence of an output LC filter. Therefore, amplifier DB chips like the MA12070 sound very good and offer an unrivaled price/performance ratio. In my projects, I exclusively use the MA12070 with low L and C values. This produces a terrible picture on an oscilloscope, but a beautiful one on a spectrum analyzer. Try getting this on a chip DA such TPA3255:
Incidentally, for these measurements, I used a simpler solution from the same TI: the RC filter. It also produces good results and simplifies implementation.
You may not forget the nature of the BD type modulation HF (VHF in fact) noise:
There are always full-scale impulses with very short rise time and fall time at the output. This saturates input circuit of the DMM, and also transmits up to tens of MHz EMI. I do not understand how such unit could pass FCC, as it effectively destroys wifi signal in the vicinity. And it is not just a question of the specific piece of SMSL A100. I have a Wondom board with MA12070 with exactly same behaviour.
The noise level is much higher than in the case of AD modulation with output LC filter. Audio range measurements are not helpful to disclose this behaviour.
Wondom board output without the filter and with the filter:
This is the amplitude response of the filter inside the BNC housing (measured with 100kohm system impedance. Remember DMM has 10Mohm input impedance, soo the -0.2dB drop disappears):
1. Not the full range, but half the range. The MA12070 uses a modified 5-level circuit instead of a 3-level one. With a 24-volt supply and low signals, the output pulses are 12 volts. Also, 90-degree pulse shifts lead to a broadening of the interference spectrum and the conversion of interference to noise.
2. The manufacturer recommends using ferrite beads exclusively in active speakers with cable lengths up to 40 cm. Why Chinese manufacturers produce separate amplifiers with any cable length using ferrite beads is a question for them.
3. I use a system similar to the one described in this document: 1 µH +220 pF. This ensures no distortion at high frequencies and sufficient suppression of the carrier and higher harmonics.
4. The absence of large capacitors results in large voltage pulses in the cables. But it doesn't produce high reactive currents or capacitance charge/discharge comparable to the speaker's operating currents. And here I'd argue which is worse.
5. This system with four MA12070 chips is used as the main one in my home. It doesn't cause any problems with Wi-Fi/mobile network or other radio receivers.
I’m finding this discussion to be quite interesting and I’m learning (or at least being exposed to new ideas) from it.
I’l take this opportunity to pose a question that might be naive. Since a relatively modest filter can virtually eliminate the HF noise from the power supply (as @SSS showed) why aren’t manufacturers adding that as a matter of course?
I figured that manufacturers see adding such a filter as an unnecessary expense since the PS noise is well beyond audible frequencies. Is it really that just that simple?
Power supplies are designed to output DC. Therefore the filter can be designed with a much lower cutoff frequency than for an audio amplifier, and therefore provide much better suppression of the switching noise.
The typical class-D audio amplifier switching frequency is about 500 kHz. The output filter is usually second order (LC filter), and has a cutoff frequency at ~50 kHz to minimize its impact on the audio band. Since a 2nd order filter attenuates at 40 dB/decade, the the voltage amplitude of the residual switching noise is therefore usually about 1% of the rail voltage.
As you can see from the last several posts, there are "filter-less" class-D amplifiers which use the "BD" modulation (3 levels PCM/PDM, instead of 2 levels of "AD"). The deciding factor of whether an output filter is necessary in these cases is if the amplifier can pass the FCC (and/or CE) electromagnetic interference/compatibility (EMI/EMC) requirements, and therefore legally sold.
This is also important with strict power consumption requirements. With the standard values of a typical inexpensive DA amplifier: 48V supply/400 kHz/22 µH/0.47 µF, the reactive currents at the modulation frequency are approximately 0.9 A. This leads to heating of the output transistors and output chokes, requiring a powerful power supply and a heatsink even with no or weak signal. There are many complaints about overheating of small boxes with high power, even on this forum. Class DB amplifiers are free from all these drawbacks, run virtually cool, and often don't even have a heatsink.
I have not read this whole thread, but high-frequency noise corrupting DMM readings is not new, though arguably much worse for class D audio amps due to their large-amplitude high-frequency (relative to audio) pulses. Especially those with inadequate output filtering. In the real world, parasitics, crossover, and driver inductance usually block the spikes from causing harm, but the meter reads them anyway. It is a very good thing to know and great that @pma keeps reminding us of this unwanted and potentially overlooked issue.
Years ago with a similar problem measuring DC linearity of a HF (1 Gs/s 16-bit) DAC I ended up doing a few things to get accurate DC readings:
1. Added a filter before the DMM to reduce HF content into the DMM;
2. Used a differential DMM input (not an option for most of us given typical DMMs) with well-shielded input leads (dual coax in my case); and,
3. Used the DMM's built-in filtering to reduce noise (again not an option for most meters).
The huge catch for any of us without access to a test lab is that the meter I used (Keysight 3458A) costs around $17k today without options, and still over $5k used. Not exactly something I have at home. But adding a filter before the input of any DMM can help; I used a fairly simple 2-4 section passive RC filter in a shielded box. The problem with the filter is that asymmetrical pulses will still produce an effective offset that may be difficult to compensate. The calibration procedure I ultimately used involved a high-end oscilloscope, reference calibrator, and perhaps most important the ability to lock the DAC into a constant state with no switching spikes so I could compare measurements with and without HF noise (which led to other issues like thermal drift). It was painful and time-consuming.
Could you explain the purpose of a differential stage here?
The DAC's output was differential, but also for noise rejection, mainly from coupled clocks and external noise sources like power supplies, lights (e.g. 60 kHz "fast start" fluorescent light ballasts), control computers, and such. I needed to measure microvolt levels in a relatively noisy production test environment.
For an audio amplifier, it depends upon the output stage topology (e.g. a bridged output would benefit) and noise sources and susceptibility to common-mode noise.
It's worth looking up how a given DMM works. Not pretty.
I use a £26 FNIRSI micro oscilloscope. Not great, not even dual channel, but good enough for home fun.
@NTK , @Mike123 , @DonH56 Thank you for the detailed explanation.
I was attracted to this topic because I was startled at how noisy some of the signals output by amplifiers are. While most output traces are nice and slim, some are "fuzzier" with much more apparent PS noise superimposed on the output.
I was shocked at how much PS noise was present on the output signal of my Dayton Audio SPA250DSP subwoofer plate amp. Here are some traces I captured when measuring that amp:
I can't fathom why Dayton Audio wouldn't have cleaned up the output on this model.
The other amps that I've looked at have done a much more thorough job of filtering out the noise from the power supply. Here is a trace from an Aiyima A07:
Although the A07 is a cheap amp (only about CAD$90), it outputs a pretty clean signal.
Here is a trace from a 3e Audio A7:
And here is one from a Topping Mini300:
These traces may not do a good job of showing the noise from the power supply. However, that noise is readily visible (and measurable) when one zooms in. For instance, the Topping Mini300 output trace isn't a nice thin line, it is in fact rather broad (about 500 mVpp in width) due to a 600 kHz signal superimposed on the output by the Mini300’s power supply.
I thought 500 mVpp was a lot until I saw the SPA250DSP was 4 Vpp!
As said above by @Davey2156 you are likely looking at the residual switching noise and not power supply noise. This might help:
Class D amplifiers switch at very high frequency and filter the output to produce a smooth output waveform (much like the image filter at the output of a DAC). The switching is rail-to-rail across the power supply (usually) so the residual can be fairly large but well above the audio band. Some amps are worse than others... There is nothing wrong with the amplifier, that is the way they work, but the amplitude of the high-frequency noise is very much a function of the amplifier's output filter.
The subwoofer amp, because it is a dedicated amp for a subwoofer driver only, probably uses a simpler output filter (and perhaps lower clock rate, which makes the switching spurs harder to filter) since the signal is not applied to any other speakers.
@Dave TR3A That's not from the power supply. That's switching from the Class D operation of the amplifier.
You would see much the same even if using a linear power supply on those examples.
@Davey2156 Wow! That's fascinating. I had thought it was due to the power supply.
IIRC (it's been a couple of years and my memory may be faulty), when I changed from the stock Aiyima 32V/5A power supply to a Meanwell PS the noise I measured on the Aiyima A07 amp shifted in frequency. The fact that it changed led me to believe that the noise had to be coming from the PS. The original post in this thread (by @SSS ) made me more confident in that belief.
How can one ascertain what noise is coming from the PS versus the amp?
Measure the noise at the power supply rails and at the output of the amplifier. Chances are the noise peaks are at different frequency since the power supply and amplifier operate at different rates. You will need an oscilloscope or something like REW or other capture and analysis system that produces an FFT (frequency graph) to measure the frequency.
A related point here is that these scopes are sampling at some massive rate - 1GS/sec and are very Wideband compared with the signal of interest, so they are digitizing the thermal noise and all the EMI picked upon on those high impedance probes. I have a Sigilent 12 bit scope and boy those traces look noisy, but in reality with 12 bits of resolution, 200MHz of bandwidth and the trace that paints/refreshes bright colored pixels on the screen for each sample, everything looks extra noisy - especially if you grew up in the era of CRT scopes!
When my old CRT 'scope finally died, I replaced it with a modern digital 'scope, which I have come to regret. The new 'scope does more, and takes up much less bench space, but I wish I'd just bought a used CRT scope for just the reasons mentioned above.
The traces always look so noisy, even with a ciean signal.
S
Actually, maybe I am just letting my Luddite flag fly*, but to me the big problem appears to be that good ol' fashioned digital hash molesting that pure, virgin(al) analog sine wave.
only joking... kind of...
:cool:
______________
* to paraphrase David Crosby ;)
