- Thread Starter
- #201
Replying once again to this fantastic post.Notes: This is intentionally oversmoothed so it's easier to understand. The 100hz dip on the 105dB line is a measurement mistake on my part, not compression. The 115dB measurement is probably invalid because UMIK-1 compresses at 112dB unless you open it up and change the gain dip switches, but it's there for fun.
So you can see my system plays almost dead flat up to 100dB, pretty good up to 105dB, and by 110dB there's compression from 50hz that reaches -4dB by 20hz. Now, some might say "well that's crazy loud" and that's not true either. I've measured 107dB bass peaks in classical music at 77dB average SPL. I'm not going to say >105dB is a common scenario, but >100dB happens all the time in the content I listen to.
Finally got around to doing some measurements on my sub.
And I see what you mean.
Below you can see my sub on its own (I know, I know, it's unEQ'd (room mode at 39hz), and also I have a Low-pass filter on it to integrate vs my mains).
I had been doing a series of 20-100hz sweeps of increasing volume.
And while the increases at lower levels had been uniform, at this level the increase at 20hz is about 1.5dB, but at 50hz it's about 3dB. Compression, as you say.
I did not continue increasing levels because I was already making all the windows vibrate and getting plenty loud to my ears.
However, and it's a big one ... it's vastly better than what I had, and at 30hz it's not half bad.
And... I have not heard a system with properly powered and integrated and EQ'd subwoofers.
So I guess I may not know what I'm missing.
For now, the lil' sub will do, and we shall see if I outgrow it.
