bennybbbx
Dont trust only Spinorama, maybe on audio science can measure a example with spinorama. I find only The Meinl Mini Cajon with builtin speaker is drum simular instrument, the 70 $ version have a 2.5 inch speaker and the 160 $ version have 2 4.5 inch spiker to play playback music. It can simulate a worse designed speaker.
Here what a Cajon is. https://de.wikipedia.org/wiki/Cajón
With the klippel NFS is mean the bass Problems of the Holographic Audio calculation of the Klippel. The Cajon test is also good to compare with a freefield measure with klippel Direct Sound Calculation. Her can see that klippel seem not able to detect speaker resonances and room resonances correct, so it reduce case and bassport resonances and frequency shifts too in the measure results. https://www.avnirvana.com/threads/k...-resonances-show-with-klippel-examples.17229/
The "CTA2034 Spec-Sheet Bass Competition" – the bass equivalent of the old loudness competition(where songs heavy compressed and distorted to be louder. music platforms have stop this).
We are experiencing the exact same phenomenon, only on bass range and worse ports give more bass range that look better in CTA 2034 but they have much worser decay times and frequency shift(read about how bass ports(simular to helmholtz resonantor works) than good bass port design or closed speakers. Result was, that Closed speakers are not available anymore, because CTA 2034 did not show the advantage of a closed speaker, it show only the disadvantage of a closed speaker(the less bass)
The Spec-Sheet Bass Competition: Why CTA-2034 Fails the Time Domain
Historically, the audio industry has always found ways to hyper-optimize single metrics for marketing. Back in the day, look at the Infinity RS 6001(have no bassport but a very bad designed crossover. The price for the size was very good) https://de.scribd.com/doc/289482001/RS-6001-Technical-Sheet It was heavily hyped but sounded terrible to many ears. If anyone complained about the bloated, muddy sound, the community dismissed it "Your room is bad," or "You just need a more expensive, high-current amplifier." Back then, this marketing trick eventually failed because consumers still had plenty of honest, well-designed alternatives, and Infinity ultimately went under.
Because the modern CTA-2034 (Spinorama) standard only measures the steady-state frequency response in an anechoic(calculated) environment, it has created a massive loophole. Manufacturers are over-optimizing their speaker tuning solely for a pretty looking graph. They pump up the port output to show impressive bass extension down low, completely ignoring what happens in the real world.
The CTA-2034 measurement completely blindfolds us to two critical flaws:
1. Time-Domain Smearing: A massive ringing and overhang that persists long past 100 ms.
2. Port Chuffing: Severe turbulent airflow noise under dynamic conditions.
Today, almost every mainstream manufacturer seems to sell these "cheater ports" just to win the graph competition against rivals. Meanwhile, truly honest speakers that offer tight, precise bass—but maybe show 2 dB less output on paper—are unfairly penalized by reviewers who only stare at Spinorama charts.
The irony is that exposing these modern marketing traps is incredibly easy. Anyone with a measurement microphone can do a simple near-field measurement directly at the bass port (at a 2 to 10 mm distance). If you look at the Frequency diagram at 100 ms in REW spectrogram and compare these over-tuned speakers to a genuinely good design, the illusion of the "spec-sheet bass" can see
We need to stop evaluating bass quality by looking at static 2D lines. It’s time to look at the time domain, or we will end up(or have it) with an entire market of glorified, booming Infinity RS 6001 clones.
this also the X grok confirm .
https://rmsacoustics.nl/papers/whitepaperbassreflex.pdf
here can see that a bass port really work as a helmholtz resonator that resonate on bass port frequency at any frequency that is input.
the input signal was a 160 hz sine. output is anything else as 160 hz on the bassport. such situations happen in real music situation when play snare drum, distortion guitar mutes, or mute bass. Producer also know the problem do slightly workaround for this. they notice when make below 400 hz mono it sound better. also Vinyl do below 200 hz make signal mono. but it is not Hi fidelity. another way to avoid this worse sound, are the techno kick. the beick begin high and then slide very low so the bassport ring fit to sound. the snare drum is thin with only few level at 160-190 hz or there is no snare drum. if there need such workaround because of bad designed speaker case and bass ports, is not HIFI. ring out passport can not cancel from the woofer driver, because the woofer driver stop much earlier without so much frequency drifts as can see on the Focal alpha 65 evo. it is not a cheap speaker.
I think a near field measure 2-10 mm and show the frequency response at 150 ms can show the problems most. so can choose the speaker with the shortest decay time if you want a precise speaker
this measure was not on bass port measure, but also the thin metal backplate ring on bass port frequency. its not my room because my smaller speaker have this problem at 45 hz not. so all come together and interact thin enclosure and worse bassport. in the focal display you can see the slowness of the focal woofer. at time 0 ms it is 2 db under max level. only after 40 ms it reach the 0 db and then decay very slow. because measure is 2 mm near, room have no important influence to that
the JBL 104 have the bass Port on back. but not such bad long decay resonances in bass. but it have resonances at higher freq. frequency below 40 hz is noise because JBL 104 output at this frequency only very little so the normalisation need boost alot
Why Bassreflex is not Suitable for
Low-Frequency Musical Sound
Reproduction
