It's an ongoing amazement to me how many manufacturers use RCA's for their SPDIF interfaces. The inadequacies of RCA's has been repeatedly demonstrated even if 75 ohm cable is used. Is this really to just save a couple bucks? Lower end McIntosh stuff has RCA's as does most Japanese gear regardless of price. It's not like BNC's are really so exotic, and 75 ohm cables are readily available. In fact, the general lack of inputs is an annoyance. AES/SBU seems to have become and exotic feature. And not everybody wants to use USB or Toslink. Rant over. Thanks for reading.
I get that this is a rant—and a good one. I'm just commenting to the board, you probably realize this...
To the first sentence, it's basically self-fulfilling. S/PDIF is basically AES3 made so cheap that manufacturers could include it,
even when most buyers were unlikely to use it, with almost no impact on cost. If this were not the case, S/PDIF would have never gained significant manufacturing support. (I have at least three devices around me that support it, I've never used it in my life.)
Not only are RCA jacks literally
stamped out of thin metal, they don't take up much panel space or depth. They work out well to gang a bunch on a molded plastic base that takes just a few screws to secure to back panel, which is already being done to support 20+ analog ins and outs for a receiver or preamp. And, significantly, the manufacturer can throw in a molded cable with plugs—no moving parts—at slight cost.
BNC is not expensive, per se, but it's a step up from almost nothing—impact to the panel, more expensive connectors and cables with tighter tolerances. So, it a nice upgrade, but when everything else has RCA, that upgrade would need to be RCA + BNC...yet TOSLINK has more utility with its noise/hum immunity, so a BNC-supporting manufacturer needs all three, or disappoint more consumers than they will please.
RCA is wretched, but at the cheapest it still works—for consumer gear that is rarely reconfigured—and allows lots of ins and outs at minimal cost.
Pro audio is a different story, but even then BNC for me is limited to digital clocks and MADI support. But my converters only have ADAT and MADI optical, so it's MADI optical. But that does highlight the, er, "beauty" of S/PDIF—at one extreme you have digital interfaces that are expensive enough that they are often implemented as an extra cost module (MADI, Dante...), despite the added cost of modularity, while S/PDIF is just there if you need it, because it's so cheap. Firewire failed at a time when it was the only good choice for things like video cameras, because it added $1 in licensing fees.
