LOL. Science, how does it work?People don't need controls to understand what they like.
Unfortunately , but not at all surprisingly, you offer no real evidence for your claim.Unfortunately measurement is very unreliable at predicting what people actually like. I cook Paella some people love it because of the 'burnt' bottom, others hate it for the same reason. It's not better or worse its what you like.
Guys, why are you engaging a rather stupid and unimaginative troll? Don’t feed, the supply of banality just multiplies.
My god, this must be the answer!Indeed. However I think that there are quite a few people, here and elsewhere, who happen to like to listen to both SS and valves. And why not...
It's just a hobby.
When you say engineered... what do you mean exactly?I have done a well controlled ABX between a engineered tube amp (Dynaco ST-70) and a high performance SS amp (Neurochrome Mod 86) and could not tell them apart even though I could measure differences.
The ST-70 was stock. When I say "engineered" I mean David Hafler used science and measurements and engineering to design the St-70 to perform as accurately as possible at the time for it's budget. This is in contrast to many modern tube amps that are designed using "pop/fad science" to be "special" and use poor ideas like no feedback in their design and measure and perform poorly. Amir tested my ST-70 and you can read the results. SINAD of ~60 distortion ~0.1% flat and extended frequency response. You can read the Neochrome specs here https://neurochrome.com/products/modulus-86 pretty much SOTA.When you say engineered... what do you mean exactly?
The ST-70 as "produced" (most, of course, were sold as kits) by Dynaco (David Hafler) has excellent output iron but a somewhat dodgy driver section, netting mediocre overall performance. A surprisingly large cottage industry of upgrades, updates, and modifications to the ST-70 (and even "manufactured" modern variants thereof, in some cases just cobbled up from upgrade boards) was spawned by the unrealized potential of the ST-70 and still exists to this day.
If the ST-70 in your test was "stock" in configuration and was indistinguishable from a Neurochrome Mod 86, I don't think that speaks too well of the latter.
If it was engineered as in improved, that could be a different matter -- what modifications/upgrades were performed on it?
I also would like to see this test. I have no doubt that pushing an amp to clipping would reveal it for many. It’s very difficult for my ears at 56 to detect much difference between my office system (tubes) vs SS (reference) at even loud-ish listening levels (around 85-90 dB) it’s a tough call. But I’m sure I can’t hear as much I as used to.People give way too much credit too their own hearing. Of course maybe I am deaf but if you think you can tell the difference between a well designed 60 SINAD amp and a 110 SINAD amp I would like to see you prove it with a valid ABX test.
audiosciencereview.com
I made some money over the years replacing them, and occasionally improved the measurements a bit. But it was actually a pretty decent design- the cathodyne insured essentially perfect balance and low source impedance, and the required swing wasn't too excessive for the 7199 pentode section. I doubt that any of my mods had significant audible consequences.a somewhat dodgy driver section
How could we not ever have seen it before?
We don't take kindly to snake oil around here, sir.Try them some time on a date, they’re chick magnets.
The weak parts of the design were in the power supply section. Moving to solid state rectification and putting in regulation had a bigger effect at powers past a few watts.
I have done a well controlled ABX between a engineered tube amp (Dynaco ST-70) and a high performance SS amp (Neurochrome Mod 86) and could not tell them apart even though I could measure differences. The subtle differences being discussed here seem unlikely to be audible with music playing (the add distortion tests on the internet show most people need very high distortion added to music, like >5%, for it to be audible) even though there are measurable differences. I don't know how to "objectively" test this but my assertion is that 90%+ of perceived "tube sound" is sighted bias.
All possible. I’d put them in a jig and measure basic parameters and see how they line up. CCS plate load, a couple of LEDs in series to bias the cathodes. That will get you mu and distortion, put a series resistor in the grid lead and see if leakage is a problem.A question for your expertise. And I’m asking in the context that I’m pretty sure I know what you think about tube rolling.
As I’ve mentioned, I have the Conrad Johnson premiere 12 monoblocks. I’ve had them since somewhere around the late 90s..
And all that time I had never changed the driver tubes until they started cacking out a few years ago. I was replacing the two GE NOS 6FQ7 Driver tubes that originally came with the amplifiers.
I started looking up replacements and, admittedly, I got sucked into some good reviews for some NOS Mazda 6CG7 / 6FQ7.
Once those were installed in my amps the sound first struck me as more lush, but then it seemed more like “mush.” It just sounded too laid back and lacked punch, didn’t sound like the amps I “knew” but more like slightly underpowered amps for the speakers. I was quite bummed out by having lost the sound I liked, not to mention the money that felt wasted.
So I panicked and tracked down some NOS GE NOS 6FQ7 to hopefully replicate the original tube compliment. And once those were plugged in… bam… there it was. The amps sounded like themselves again. it was back to punchy powerful sound.
So my question is, sighted bias is an obvious plausible explanation, but if that wasn’t the case, might there be another technical explanation for the type of “ under driven mushy” performance with the MAZDA tubes?
I would imagine you can get some crappy results by putting the wrong tubes in an amp that it was not built around?
Is it possible that those were the wrong tubes?
Or since they were old tubes (claimed NOS) could they have been defective?
Thanks. I don’t have such equipment. But it is informative enough to know that its possible there was just something wrong with the tubes.
Busted.I made some money over the years replacing them, and occasionally improved the measurements a bit. But it was actually a pretty decent design- the cathodyne insured essentially perfect balance and low source impedance, and the required swing wasn't too excessive for the 7199 pentode section. I doubt that any of my mods had significant audible consequences.
I played a little (too) fast and loose with my reply. Thanks for weighing in!
