L5730
Hi all,
It seems that USB 2.0 spec. of 500mA current limits the possibility for a DAC/HP amp combi unit to output more power into low impendence headphones. Any one know a reason why devices aren't taking advantage of the USB-3+ specifications or USB-C where higher currents can be drawn?
I appreciate that some users would moan and grumble about a device not working as expected due to plugging it in and finding not enough current is supplied, but that already happened with external storage devices and older laptops not quite delivering the 500mA from their USB 2.0 ports and wasn't really that big of a deal (powered hub / USB Y-cable).
Is it more a case of actual voltage supplied to the device that is required to produce the current for driving harder to power headphones/IEMs? If that would be the case, then I can see pulling more current from USB would require generating more voltage and probably introducing a load of unwanted noise, so a no go.
