Technics makes good turntables, but in my opinion, they are not the kind of be all end all vastly superior things some people seem to hold them.
Direct drive is indispensable to DJs, but for normal home usage, belt drive is perfectly fine. A belt drive requires a bit more maintenance, and it takes couple of seconds to reach the correct speed, but if ease of operation is paramount, then one should stay with the digital media anyway.
A quartz controlled direct drive can achieve very good speed accuracy, but the direct connection between the motor and the platter does not provide the kind of isolation from vibration and noise, as the belt. Technics has solved this drawback better than most, but there are still belt driven turntables that offer lower noise, hum and rumble through the groove, while still maintaining speed accuracy that is easily good enough,
