Bland_username42069
- Joined
- May 6, 2024
- Messages
- 203
- Likes
- 173
I can’t see the point in measuring turntables - direct drive has the best wow/flutter and rumble and technics is the best of the new direct drives so we know the standard.
CDs are dead-flat from DC (0Hz) to about 20kHz. The high end is absolutely limited to 22,050Hz (half the sample rate) and there is filtering so it doesn't that high but it's usually pretty-flat to 20kHz. Some CD players (most?) filter-out the DC and very low frequencies. It isn't "sound" and it can sometimes cause problems.CD has better bass and sometimes more detail
How do you measure the lateral force it generates?
I don't think anything you've written is correct.CD's are dead flat, but that is only the data, the electronics and in particular the analogue outputs are not, and they have distortion, also CD data produces high levels of (Audio) hi frequency distortion ( in the D-A stage) which in early players was around 11% at 8kHz and got worse at 10kHz, so it is the whole play back system that counts not just the 'data' medium.
Correct, Phono cartridges and phono amps are not perfect but high-end ones are pretty good 30 dB Channel separation 90dB dynamic range 15Hz to 40kHz. The bass is attenuated according to the RIAA curve specifically so the reverse curve can be accurately generated by the phono stage - modern good ones are within 0.2 dB 15Hz to 20kHz.
And yet, their current offerings range in price from less than 1K USD to more than 10K despite very similar W+F specs. I wonder if I'd be able to discern differences between the most and least expensive in a DBT.I can’t see the point in measuring turntables - direct drive has the best wow/flutter and rumble and technics is the best of the new direct drives so we know the standard.
The dynamic range of an LP probably isn't even 80 db. And turntables reach for 80 db as a noise floor, probably more like 75db. Again, the real point is finding out the point that people would find the deficiencies acceptable. The "high-end" Technics SL-1000R has a (weighted) noise floor of -74.9/-74.1 db and other noise noise/hum of -60 db. My cheap Topping E30 DAC has a SINAD of 112. Really no contest.What is an example of a CD player that did this?
What is an example of a phono stage that has 90 dB dynamic range?
High 70s / low 80s for MM is pretty good.
Also, the dynamic range of LP itself isn't 90 dB / 15 bits, so it's pretty moot.
False.Direct drive doesn't wow because it uses high speed correction, they jitter instead like a CD.
Easy, two tractor beams, and measure the difference.
"the Spartan 15 Mk 2 is said to deliver a digital-audio level dynamic range of over 110dB"What is an example of a CD player that did this?
Just came in to mention the WallySkater, looks quite fiddly but was interesting to see how to 'measure' skate.A calibrated spring aligned horizontally and connected to a vertical push-plate, like a tiny version of a bathroom scale on its side?
A string with a hook around the tonearm, going around a pulley with a weight hanging from the other end?
A Wally-Skater? I never heard of this before, but apparently it's a thing and Stereophile reviewed it (FWIW).
Suspended weights don't apply a constant force. The weight pulls with a constant force on the string (or whatever), but the bar on which that string sits usually makes a rotational movement which results in a lever with different lengths as the tonearm moves across the record.I know, that is my point. Different turntables & arms use different methods to apply anti-skate forces. Some of these methods (such as a suspended weight) apply a constant force, others (such as springs) apply a force that increases or decreases as the arm moves across the record. It may be useful to measure this.
The wallyskater doesn't measure skate, it measures antiskate. That's a fundamental difference.Just came in to mention the WallySkater, looks quite fiddly but was interesting to see how to 'measure' skate.
I did. You made a set of statements, each of which is false. What's more, your extraordinary claims were backed by no evidence.Feel free to fact check any of the commentary
Thanks for doing reviews and thinking about measuring turntables!As I noted, I can characterize the speed and could do resonances. Seems like a lot of logistical work to produce two graphs. Are folks going to be happy with just that?
My advice would be not to bother since there are too many other variables affecting the output which you won't be able to consistently or universally measure. The speed apps on phones are probably accurate enough and the influence and magnitude of resonance in different parts not transferrable.As I noted, I can characterize the speed and could do resonances. Seems like a lot of logistical work to produce two graphs. Are folks going to be happy with just that?
Which phone apps are accurate? I have both versions of the RPM app on my iPhone and it measures consistently high on speed when compared to the Waxwing speed test. The Waxwing measures exactly 33.33 and 45.00 every time I check on the Technics 1300G. Phone is always high by a fraction of a percent. Waxwing is absolutely accurate because it counts the runout click of once per rotation.My advice would be not to bother since there are too many other variables affecting the output which you won't be able to consistently or universally measure. The speed apps on phones are probably accurate enough and the influence and magnitude of resonance in different parts not transferrable.
accurate enough for meWhich phone apps are accurate? I have both versions of the RPM app on my iPhone and it measures consistently high on speed when compared to the Waxwing speed test. The Waxwing measures exactly 33.33 and 45.00 every time I check on the Technics 1300G. Phone is always high by a fraction of a percent. Waxwing is absolutely accurate because it counts the runout click of once per rotation.
I don't think with respect, that I've ever seen tech tests on CD players showing 8 - 10% distortion at high frequencies - THAT's more a vinyl issue at loudly cut side ends...CD's are dead flat, but that is only the data, the electronics and in particular the analogue outputs are not, and they have distortion, also CD data produces high levels of (Audio) hi frequency distortion ( in the D-A stage) which in early players was around 11% at 8kHz and got worse at 10kHz, so it is the whole play back system that counts not just the 'data' medium.
And then we throw this into a room with speakers which may have a max SPL of say 105db - subtract the noise floor at 50 if you are lucky add 3dB because we can discern stuff in the noise floor and we end up with 58dB, but then we turn on the aircon or the wife gets the vacuum cleaner out or we have some horrible room modes and we can only really get 30-40dB dynamic range and variations of 5-8 dB in level across the audio spectrum.
Specs are fine but data source to spatial delivery is what we need to really look at and the whole delivery chain needs to work together.
