- Joined
- Jan 16, 2026
- Messages
- 13
- Likes
- 64
Introduction
Crossover frequency is one of the most important aspects of loudspeaker design, significantly impacting overall performance. Among other factors, a smooth transition of directivity between drivers is crucial for sound quality. However, the common opinion that lower crossover frequency results in smoother directivity of the system is not always correct, and reviewers often misinterpret the reasons for directivity errors in some loudspeakers. In fact, in many cases, speakers can benefit from a higher crossover frequency. In this article, I will describe the directivity pattern of drivers in rectangular cabinets and suggest a rule of thumb that can be useful for both professional and enthusiast speaker builders.
The driver's directivity is just a part of the picture
A popular explanation for directivity index problems in loudspeakers is that the transition between drivers happens where the woofer is narrow and the tweeter is wide. In reality, the difference between a 5-inch or a 6.5-inch woofer and a non-waveguided tweeter is not that significant, and using a 2nd order crossover at frequencies between 2000-3000 Hz on an infinite baffle, it is possible to achieve quite a stable transition in the horizontal plane. What makes it problematic to achieve a smooth overall directivity index in a typical rectangular cabinet and non-coaxial design loudspeakers is edge diffractions and vertical lobing.
The cabinet is a waveguide
Edge diffraction is not only something that might change the on-axis frequency response of the speaker, but also the off-axis response. The amount of sound power the driver radiates remains stable, and the peaks and dips observed on-axis are often a result of the sound power distribution from off-axis directions. Let's look at some interesting examples.
The graph below shows the normalized horizontal directivity of a 3-way speaker. The midrange driver crossover frequencies are 380 and 2850 Hz; its location is at the center of a 350 mm width baffle. The distance between the center of the driver and the edge of the speaker cabinet is 175 mm, which is equal to the wavelength of 1960 Hz; the half of this frequency is 980 Hz. That is the place where the directivity dip appears, after which a dramatic rise happens.
Another similar example of a loudspeaker that has a midrange driver operating in the 550-2500 Hz range on a 300 mm-wide baffle.
These examples illustrate the pattern of loudspeaker driver directivity in rectangular cabinets, where the crossover frequencies are far from the problematic region. Once the cabinet width is smaller, it becomes more complicated to distinguish this baffle effect from directivity changes due to driver transition. In the case of a centred driver position in a 200 mm-wide baffle, the directivity dip is concentrated around 1720 Hz, while the directivity peak is around 3000 Hz (x1.5-2 from initial frequency).
When two problems compensate for each other
Another significant factor affecting overall speaker directivity, aside from the drivers themselves, is vertical lobing. The dips in vertical directivity index are usually significant around the crossover frequency between a typical midbass/midrange driver and tweeter, even below 2000 Hz. When we summarize horizontal and vertical directivity in overall directivity indexes, these lobing dips may appear at the same frequency as diffraction dips; as a result, a massive drop in overall directivity appears, followed by a sharp rise. The example below shows a 2-way loudspeaker (6.5-inch woofer + non-waveguided tweeter) with a width of 216 mm and crossover frequency 1600 Hz. The lobing amplifies the diffraction effect.
On the other hand, lobing around x1.5-2 from the initial baffle frequency may help smooth out the directivity rise caused by diffraction. Another example is a 2-way 231 mm-wide bookshelf loudspeaker (6.5-inch woofer + non-waveguided tweeter) with a crossover frequency of 2600 Hz. Here, the lobing levels out the diffraction effect.
An obvious solution is to use full-range / coaxial drivers in rounded/beveled cabinets to eliminate both problems. However, there are not many coaxial drivers with stable on and off-axis behaviour on the market available for small manufacturers or DIY enthusiasts. At the same time, cabinets with significantly rounded or beveled edges require additional material thickness, equipment, costs, and external design compromises.
An additional option is to displace speaker drivers from the baffle center. This way, the diffraction effect from the left and right edges can be divided into different frequencies. To implement this approach, the diameter of the midbass/midrange and tweeter drivers must be significantly smaller than their baffle width.
The tweeter's waveguide may help eliminate the directivity rise after the crossover frequency. Although if the problem of the directivity dip remains the same, the overall directivity index will have an obvious step, which creates a sound power dip in the midrange.
An effective way to achieve smooth directivity in typical simple design loudspeakers is to choose the crossover frequency far enough from the diffraction directivity dip. Even better if this crossover frequency lobing compensates the rising directivity after diffraction frequency, which happens at around x1.5-2 of the baffle width frequency. For example, for a 5-inch woofer and 2-way design speaker with a 0.174 m baffle width, this diffraction directivity dip will appear at 0.5*343/(0.174*0.5)= 1971 Hz. An optimum crossover frequency lies between approximately 3000 and 3500 Hz. This simple rule of thumb may help professionals and enthusiasts prepare more suitable baffle dimensions before building a speaker prototype, or to achieve smoother directivity without making polar measurements.
I would be interested to hear about the reader's personal experience or approach. I am aware that there are some counterarguments; for example, a higher crossover frequency narrows the vertical listening window. So feel free to express your opinion.
