Why listen yt audio on pc has crack sound when win os notification pop up
derekchan
Is this normal if there is crack noise watching youtube video on usb dac when win os notification pop up
It is dacmagic 200m and 8010a speaker usb connected to pc
Does sampling rate of yt audio conflict with win os sampling to cause crack noise when playing youtube video but win os notification sound interrupted?
It depends on the crackle side of things: is it like clipping / distortion? Then win sounds setting level is too loud. If it is like the DAC is struggling, maybe win is taking control of the device when playing system sounds, which may result in the DACs buffer not being filled in time upon request.
Have you tried playing local files instead of YT sound, just to see if the problem is common, or indeed affects only internet streams...?
Just my 2c
Just my 2c
I am interested to test htpc audio on mrx740 via optical or usb connect to eversolo usb dac a8
To test out if a expensive external pc audio out device has better performance than cheap dac200m
You can have astonishing performance with a DAC that costs no more than 80 bucks nowadays... non need for one that claims magic and thus costs 3K...
do you need upsample 44khz and oversample 16x
is it necessary
does it modify the bit data of 16bit 44
Oversample where? On your PC? No need. In the DAC? Yes, required for faithful reconstruction.
As mentioned by @Nutul, investing thousands of dollars / euros into a "better" DAC is almost always a waste of money unless you need very specific features only offered by that DAC (Dirac or Trinnov room correction, 7.1 decoding and similar capabilities).
do you need upscaling 16bit 44hz from input on 40bit sharc chip?
non oversampling sound the audio d a conversion in netural natively way
what regular 2.0 dac hardware lack to decode 7.1 like dts hd ma
Again: Your source does not need to upsample anything. You can do it, but there is no need. Apart from very few exceptions (like broken NOS DAC designs), upsampling is irrelevant for the user because your DAC/processor handles it for you.
Sorry, but I don't understand. Is this a question or a statement? Maybe you could use a translator like DeepL.
