Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Welcome to ASR. There are many reviews of audio hardware and expert members to help answer your questions.
Click here to have your audio equipment measured for free!
I'd scrap that overhead light most likely, and would definitely go for a higher ceiling if possible. In my main listening room there's a cathedral ceiling with complex surfaces up to nearly 20ft high. It makes a tremendous difference acoustically, but then so does carpeting and numerous other treatments.
Yeah adding clarity is good. I wasn't writing to call you out or anything. As I said, I personally think "back wall" should be enough. I'm just thinking its easy to avoid confusion with a few more words. So many people have never heard these phrases.
In my case, behind-between the L&R speaker systems, I have a room (actually our dining room) of rather acoustically dead.
And, behind my listening position I also have Japanese odd-shaped (not a simple rectangular) room with tatami(畳)-mat (Japanese heavy-thick-straw mats) and thick-paper-covered sliding doors (fusumas 襖); the room is quite/almost-perfectly dead acoustically.
As I shared in my post #11 above, however, I have small portions of "wall and sliding doors" behind the L&R speaker systems, and I have also a small wall left-behind of my listening position. Furthermore, I have left-side (looking from listening position) side wall "behind" the amplifiers etc. and right-side large-thick-double-glass-layer sliding-windows-doors (facing to our garden) usually doubly covered by thick drape-curtain and thin lace-curtain for sound insulation/absorption.
The ceiling is covered by diatom-panels carefully selected for proper sound absorption/insulation, the wooden floor is covered by a large carpet again carefully selected for proper sound absorption.
So,,, I need a lot of words describing my "walls, etc." in my listening environments. This is why I prefer sharing some photos of my listening room/environments which would worth hundreds (thousands?) of words.
Ref. here and here on my project thread for the latest system setup...
I tend to agree, but we must consider the typical sensitivities and confusions of our American brothers. They can't help but be a bit confused, and use weird langwich at times.
I think the wall behind people is mostly not even talked about, unless they have surround sound or if the wall is very close behind them causing tons of reflections
Kyuu I'm here as I've honestly realized how far off I was with this, where you were spot on here. Your bringing 'points of references' forward in particular Sir.
Let me thank you.
Everyone knows that the wall behind the main speakers is properly called upstage. Side walls may be interchangeably referred to as stage left / house right and stage right / house left.
