Yeah, it's easy for those of us who use multichannel. It's only the stereo guys who suffer from the ambiguity.I consider the rear wall to be behind me where my rear speakers are hanging.
I tend to agree, but we must consider the typical sensitivities and confusions of our American brothers. They can't help but be a bit confused, and use weird langwich at times.I'm working class English. As such, the main room in your house, you know, the one with the settee in, is always called the front room, no matter where it's situated.
Bollox to all that 'living room', 'sitting room' and 'sofa' or 'couch' nonsense!
Back on topic, the rear wall when setting up your hifi is always the one behind your speakers. Them's just the rules. Surely!?
We're running in argumentative circles here. As already mentioned, it depends on the mental priority and viewpoint: speakers, or listener.It's called Front Wall and not Back/Rear Wall since it's in front of you.
The speakers are not the subject here, you the listener are.
Oftentimes the speakers are, in fact, the subject.It's called Front Wall and not Back/Rear Wall since it's in front of you.
Even worse: any sufficiently good optical mirror doubles as a near perfect acoustic mirror.OP understates the case. What if there is a full sized mirror behind the speaker, showing what is behind me? What is rear now???
Sacrilege!It's called Front Wall and not Back/Rear Wall since it's in front of you.
Again, then: in this case what will you call the wall behind the listener?'Rear wall' refers to the wall to the rear of the speakers facing the listener.
It's not complicated
Don't give people ideas! A few months from now we may see $100,000 "Hifi audio grade" mirrors on the market.Even worse: any sufficiently good optical mirror doubles as a near perfect acoustic mirror.![]()
back wallAgain, then: in this case what will you call the wall behind the listener?
If you take two and position the second one on the wall behind you (the front wall according to this thread, as opposed to rear wallDon't give people ideas! A few months from now we may see $100,000 "Hifi audio grade" mirrors on the market.
"the wall behind the listener," why not simply use that? You already solved the problem.back wall
four of them in a room completely cancel all wall reflections for the purest audio in a nearfield setup.If you take two and position the second one on the wall behind you (the front wall according to this thread, as opposed to rear wall), the acoustic improvement will obviously repeat and oscillate infinitely, only limited by the absorption of air. Oh the possibilities!
The terms "the wall behind the listener" and "back wall" are interchangeable."the wall behind the listener," why not simply use that? You already solved the problem.
One can clearly be misused without the context of whether or not you are referring to the wall behind the speaker or listener, just as "rear wall" is.The terms "the wall behind the listener" and "back wall" are interchangeable.
One is five words long, the other two.
For clarity, 'back wall' always refers to the wall at one's back.One can clearly be misused without the context of whether or not you are referring to the wall behind the speaker or listener, just as "rear wall" is.
The other one can only be interpreted incorrectly if the person interpreting it is intentionally daft.
I personally think "back wall" should be enough, like you do. Though, apparently there is somehow confusion, so why not be completely clear and concise?
