And yes - driving the clocks LT1963 regulator with a battery brings a slightly better sound. Compared with an average spdif output from a regular CD player to a dac, this option is often better sounding
Uh huh...
I think it's USB to S/PDIF?Best I can tell is this is some box to convert USB to PCM coax?
Why not just get a half decent DAC?
I was very sceptical myself if different USB bridges could make an audible difference. Heck, I even thought that a Yamaha wxc50 was the ” endgame” in streamers and the difference people heard with better gear was all in their imagination. I was wrong.Uh huh...
Setting aside the possibility of some problems being fixed in some cases (whether it be ground loops, dropouts, whatever)...I was very sceptical myself if different USB bridges could make an audible difference. Heck, I even thought that a Yamaha wxc50 was the ” endgame” in streamers and the difference people heard with better gear was all in their imagination. I was wrong.
Try it for yourself.
As I wrote earlier: Using XMOS ( as they did in FX audio and all Topping dacs ) seems to bee a good and cheap way to bring asyncronuos conversion and put away the 8 kHz USB packet noise, plus gaining 24 bit dithered digital volume regulation in some cases.I was curious about the signal quality of USB bridges too as I use them to convert USB audio to SPDIF to feed a miniDSP 4x10 a digital signal to bypass the A/D stage of it. Amir recently tested a cheap FX Audio DAC-SQ3 feeding a Topping DX3-Pro and compared it against directly feeding it from his AP - no difference except maybe removing a couple power supply spikes from the AP below audible threshold on the FFT.
This one I just tested does not degrade performance :I was curious about the signal quality of USB bridges too as I use them to convert USB audio to SPDIF
Thats a pity .The digital output of these devices is a pass-through so no digital volume control unless you use the analog outputs.
InterestingThis one I just tested does not degrade performance :
PHIREE U2S 2019 & Douk Audio U2 Review and Measurements (Digital USB to S/PDIF Interfaces)
PHIREE U2S 2019 & Douk Audio U2 Review and Measurements (Digital USB to S/PDIF Interfaces) Update March 2022: Added comparison with the Douk Audio U2. Here is a quick review of the PHIREE U2S 2019 digital interface. This is basically some USB to S/PDIF converter that allows you to get USB...www.audiosciencereview.com
I will now confound you I use a Windows PC with Xonar PCI-E card and optical SPDIF out to a fully digital amp, another Debian PC with USB out to same amp, and a Debian server (HP Proliant) running a UPnP renderer with USB audio out to a Topping D10 which then passes the digital stream to that same amp via COAX. Yes, I use optical, coax and USB all together. Oh, the heresy, the joy. But that's because I have a few different machines and slightly different requirements for certain of them.I have been "out of the game" for a while. When I was last paying attention, around 2011-2012, the USB interfaces on most DAC were terrible.
You would literally get "crackles and pops" especially at higher res streams (e.g. 96k). Usually Coax SPDIF was the "best" way to connect with a DAC.
It seems that the USB issue is now "solved" with XMOS 208 and 216 chips. But it seems to me that USB is fundamentally a poor interface for audio, and we have had to invest a lot to work around USB's limitations.
It also seems that almost all PCs motherboards have dropped Coax SPDIF output, but almost all of them still have TOSLINK SPDIF output.
So two questions:
1) why don't more of you have PCs setup as the fundamental source using PCIE SPDIF output rather than USB?
2) why did mono makers select TOSLINK over Coax for their remaining SPDIF interface? (I recall TOSLINK is almost always more jitter/less bandwidth)?
Does Douk U2 (XMOS) driver support ASIO? At almost twice the price of the PHIREE U2S, not sure about what it can bring to the table, except 192Khz support.Interesting
My Douk U2 is also good sounding.
The Douk U2 has three separate clocks , one for dsd and one for 44,1 kHz, the third for 48 kHz.Does Douk U2 (XMOS) driver support ASIO? At almost twice the price of the PHIREE U2S, not sure about what it can bring to the table, except 192Khz support.
I seem to recall when I purchased my Bifrost 1 that Jason was pretty clear at the time that USB was very problematic to implement for audio and while they included a USB connector, they certainly suggested either optical audio or coax connections. That DAC is 12 or 14 years old, and while I have it hooked up to my Mac via the optical audio connector for headphone use, I am likely to update that with a Bifrost 2. Doing so will also put me in a ready state for when Apple updates to a new silicon 27” Retina iMac, hopefully in the near future. I hadn’t really lurked around here for several years, so to now see USB as the standard for audio and outperforming Toslink is a bit of a revelation.Schitt had to work on their usb interface because until unmasked here their usb isolation was unusually schitty.
It won't do multichannel.1) why don't more of you have PCs setup as the fundamental source using PCIE SPDIF output rather than USB?
Um… none of the DACs do multichannel do they? Sure and AVR will, but that’s not what 90% of this site is about. Or am I missing something?It won't do multichannel.
I own 2 and there are others.Um… none of the DACs do multichannel do they? Sure and AVR will, but that’s not what 90% of this site is about. Or am I missing something?
There is also ADAT that can have 8 channels 24/48 but I don't know of any receiver that has that support. RME supports both ADAT and S/PDIF on their optical input/output.
that's a total nonstarter.
All that needs to happen is for both laptop and AVR USB I/O to be compliant with pro audio USB (which is already long used for multichannel)
Apparently it hasn't?
