Hello everyone,
this is my first post here, but I am not new for this forum. I've been lurking for over a year and I must say that I really appreciate everything you are doing. You have already helped me in getting started on a nice Headphone setup (KTB + O2). I have not found a similar thread on this forum. If there is one, feel free to close this and just direct me there.
For a few months now I have a home theater at home. I have some nice DIY-speakers in the front (surrounds to be upgraded soon™) and a Denon X-3500H to decode and drive everything. And it's working nicely. For video I can connect all my HDMI sources effortlessly and if I just want to listen to stereo music I can use Spotify connect to play music directly from the Denon (again, effortlessly). It even has Audyssey XT32 which gives subjectively much better sound, though I assume that's mostly because of it's "dynamic volume" which add bass and treble when listening below reference level. I mostly listen on lower volumes.
Now my dilemma is this: I have the urge to buy dedicated stereo equipment for music listening. In my mind I would like to have something like a KTB (or LA-QXD1 once it's available), a Hypex-based amp (probably containing the NC122MP) and a Raspberry Pi running volumio as the source. Also I would have to add a passive RCA switch to switch between the Denon and the stereo setup.
But why should I do that?
According to the measurements from this site, the Denon is "terrible". It barely got a pass in its review. Mainly because of it's poor DAC implementation. But even the 73db SINAD of the Denon's DAC should be inaudible, no? So why should I go ahead and spend a lot of money and time to make my setup more complicated but not audibly better?
I know this might seem like I am trolling, but I am genuinely curious and I would like to know what the opinion of you guys on this is. Because I cannot quite understand the mindset that many folks on this forum have. On one hand I often read "the distortion is there but it is so low that you will not hear it", on the other hand even in this forum people are spending 1000s of dollars/euros for equipment that - according to the measurements - does not sound different from equipment that could've been gotten for a tenth of that price.
I know there are some sound-unrelated differences like build-quality or I/O options (balanced I/O) that can be better in expensive products but honestly for me personally a shiny case is not worth a 4-digit amount. Also I don't need I/O ports that I don't use. And even balanced I/O, which a lot of people in this forum seem to prioritize when selecting equipment, is not really necessary in a typical living room, is it?
So to conclude, when the measurements show no sign of audible difference between cheap and expensive gear, why do you invest money into expensive audio components and why should I?
