Soandso
- Joined
- May 30, 2022
- Messages
- 2,149
- Likes
- 4,762
Brunswick was one of the earliest (1916) USA recording studios that by 1930 with corporate partners had a US$ 28,000 (=U$ 538,500+ in 2025 dollars) mobile recording set up that weighed 1,600 pounds. Performers played in a room whose microphone cable sent the audio signal into a glass windowed sound proof room. There it was amplified and one person listened to a single speaker allowing him to order stop(s) and re-doing(s) unwanted performance(s) from the beginning. Another person with simple headphones on was tasked with controlling the onward passed audio signal volume to the recording equipment.
A technician operating the recorder had lots to do. He had a warming oven with multiple flat (not cylindrical) discs with a 1 and 1/8th inch thick coating of a proprietary metallic soap "wax" ( not rosin or bees wax) that in horizontal size were 2 inches greater in diameter than the proposed final record. One of these lathe polished (often recycled) "wax disc" was placed on a turntable, the metal recording needle placed on it's edge and a few test turns of the rig making grooves were made, a vacuum sucked away any filaments and a microscope was slid over there to verify operation and production conditions were acceptable. Only after that would the recording technician place the needle in the actual staring position and authorize a new performance could start.
[Later the cut disc's "wax" was dusted with fine graphite (sometimes first dipped in an acid) to make the recording disc's "wax" surface conductive, then it would be electroplated with a final copper layer applied. Once done the "wax" got broken away leaving copper ridges corresponding to the recorded grooves so that when that plater were then "stamped" it created a finished records' grooves. In those days the ridged plate was called the "Mother", not a "master".]
