Again, Dr Toole to you & us.
There is nothing do to with SQ between the two, in fact they are not even separate categories.
Active DSP systems simply means the EQ / filtering happens at the line level, not after amplification.
Whether the amplifiers and processing are physically internal or not is irrelevant.
Your question was already answered above, yes there are some very well implemented passive speakers but they are few, and not cheap.
DSP's ability to improve any flaws in the more common passive crossovers of cheaper speakers would be limited, a fully active system (each driver getting its own separate channel) gives greater possibilities.
But then, the owner must become a speaker designer, the DSPing skilz level becomes the weakest link.
Getting blind level matched ABX testing going with statistically significant panels and rounds is the only way to get "semi-objective" about human preferences. No "laboratory" needed, but it does take a fair bit of effort to set up
and so far, transparency in reproduction (as measured) has correlated with the results of those type of testing.
That bit throws EVERYTHING out the window, obviously measurements must guide you even if your individual (biased) judgment is your final arbiter.not about laboratory tests, but from the perspective of psychoacoustics.
