I have a question.
If a speaker is designed to be listened to off-axis e.g. at approximately 30 degrees, then at what angle should it be evaluated in mono?
Maybe someone should do research on whether the manufacturer's stated off-axis recommendations are legit.Such as previously mentioned, but if you want some examples, see below.
Dali speakers are designed to be listened to off axis.
Andrew Jones has mentioned he has designed with off axis in mind as the presumption is most customers will use this way.
Kef recommend starting with no toe in to the listener, so approximately 30 degrees to the main listening area best spot.
Lots of manufacturers have turned mismatched directivity into a game. Like B&W, do people really like the treble or have they just not found the perfect angle...
