Paperback is back in stock, at 25% off, though there is now one less available!
Sorry to bump up an old post in this thread, and this might have been brought up earlier, I just didn't read through all 42 pages.Sorry that the earlier editions of my book were not useful, but thank you for persevering.
For the 4th edition I reconfigured the data as shown here. The quality descriptions of the loudspeakers are related to the number of audible resonances - best being the most neutral sounding.
It makes it very evident that adding (simultaneously active) channels makes us less sensitive to resonant coloration in loudspeakers. Although only the mono ratings showed statistically significant differences, there are interesting trends to be observed. First, the "best" most neutral loudspeaker was highly rated in all comparisons. As channels were added the range of perceived sound qualities reduced, and the small differences between the sounds appeared to be differentiated more clearly, albeit not with statistical significance. More tests would have been required to obtain statistically significant differences with higher channel counts, but clearly the important point had been made. Clearly, hearing the differences is easier, and more sensitive when listening in mono, which is why it is the preferred technique.
This was a useful experiment, especially in that it showed persuasively that equalization of anechoic data can attenuate the audibility of resonances, and that equalization based on in-room measurements misses audible defects.
Here is a post with Dr Toole's thoughts on a similar question. Hope this helps.Sorry to bump up an old post in this thread, and this might have been brought up earlier, I just didn't read through all 42 pages.
Would you say that it's wise to not go for the objectively best speakers if one is putting together a multi channel system, in view of the results above? If even inferior speakers sound comparable to well engineered ones in a multi speaker setup, why spend more? If one plans to always have all the speakers on, even when listening to stereo, it makes sense to not overspend as the end effect will be subjectively comparable.
I saw a very similar answer from Dr Toole in another thread. He said, get 5 Revel bookshelves and 2 subs. But that Revel is a $1600.00 per piece and once there are five of them playing simultaneously, they are almost indistinguishable from five JBL LSR305 (if we are to believe the graphic) that cost $1000 all together. So why spend $8k on all great speakers?
I get that these are well engineered speakers and would do great in a home theater setup. The original question is why bother with well engineered speakers if the fact is that five of them sound subjectively similar to a set of clearly inferior speakers that might cost much less. That's what the graphic in question conveyed.Get five Ascilab F6Bs speakers for $350 each. @amirm's conclusion: "Amazing what happens when you follow audio science and engineering to the max: you get a very reasonably priced, gorgeous speaker that is near perfect objectively."
If you can show that this is indeed the fact, many, many people will be greatly interested! It may be true, for sure! (although those ascilab prices are already so reasonable it's hard for me to imagine...)if the fact is that five of them sound subjectively similar to a set of clearly inferior speakers that might cost much less.
It's funny that no one wants to touch the original question. It was not about money per se. It was about the utility of a well engineered speaker in a multi channel setup. The money question is related, but not that important here. It could be the opposite for all I care. The objectively inferior speakers could be a Martin Logan and the superior speaker could be the Asci Lab F6b at a fraction of the price.Whether the outlay of more money is worthwhile is a subjective evaluation, and as such is one that neither science nor logic can answer. Only you can answer it. For many people in this hobby, personal finances are the major consideration, and control many choices.
That's what the graphic in question implies. The crappy speaker sounds comparable to the superior one, once there are multiple playing at the same time. It's not my claim, it's Harman research. https://www.audiosciencereview.com/forum/index.php?attachments/448684/If you can show that this is indeed the fact, many, many people will be greatly interested! It may be true, for sure! (although those ascilab prices are already so reasonable it's hard for me to imagine...)
no, the graphic shows nothing about cost.That's what the graphic in question implies. The crappy speaker sounds comparable to the superior one, once there are multiple playing at the same time. It's not my claim, it's Harman research. https://www.audiosciencereview.com/forum/index.php?attachments/448684/
It's a distinction without a difference.The graphic being referred to doesn't show that any old terribly performing speaker will sound just as good as a well-performing speaker in a multichannel setup. It merely shows that it's more difficult to discern flaws when you increase the channel count (hence why our host judges speakers in mono).
Importantly, you don't have to spend a lot of money for well-performing, neutral speakers. My system, for example, cost $350 each for the front LCR and they are excellent performers.
Also, you have to keep in mind that program material will sometimes be in stereo or even mono, you're not going to have content blasting on all channels all the time and the flaws will reveal themselves in those moments even if they are otherwise masked in multichannel content.
Your question(s) were rhetorical, because you answered them yourself. 'Funny' indeed.It's funny that no one wants to touch the original question.
I wrote "crappy" not "cheap" in the post you quoted. Crappy could be more expensive than a well engineered one. This question is not primarily about saving money. It's about the findings of the research. Money savings are a potential side effect, but not the main purpose of the question.no, the graphic shows nothing about cost.
again, good sounding speakers (ascilab) are very affordable nowadays. If you can find cheaper ones that are just as satisfying in that multichannel arrangement (which you may be able to do! I'm not expressing skepticism, just asking to move from hypotheticals to reality!) then that is of high interest to all budget-minded consumers.
Consider the fact that recordings often have at least some predominantly monophonic sounds, in which case you'll hear the crappy speakers for what they are.The original question is why bother with well engineered speakers if the fact is that five of them sound subjectively similar to a set of clearly inferior speakers that might cost much less. That's what the graphic in question conveyed.
Yes, and Toole has pointed this out in several posts and notes.Consider the fact that recordings often have at least some predominantly monophonic sounds, in which case you'll hear the crappy speakers for what they are.
I think Dr Toole might disagree. But that's why I asked in the first place.in which case you'll hear the crappy speakers for what they are.
It doesn't matter if you are using an up mixer, that doesn't mean you are going to have correlated material in all channels at all times that will mask the flaws 100% of the time.It's a distinction without a difference.
As to the content being in mono or stereo, I specifically wrote in my first post that the question is about using all speakers for all material, like many home theater receivers allow.
I'm not so sure:I think Dr Toole might disagree.
But, mono signals exist in multichannel recordings whenever there is a hard-panned image. The most blatant example is the center channel in movies, which does most of the important work, delivering most dialog and much on-screen action sounds. Solo instruments also appear in single loudspeakers. These are monophonic listening opportunities and this is why, even though there is an overall degradation in one's ability to hear resonance colorations in loudspeakers in stereo and multichannel recordings, in the end, listeners still prefer the most neutral loudspeakers.
