Maybe I'm mistaken to see a correlation between such observations and equal loudness curves; that certainly seems to be a disputed correlation to make. My observations are in the same general ballpark as both of yours.
This is a 'might be' reiterated, but I would expect the correlation explained as a chain of causation.
David Griesinger finds that time coherence (phase coherence + arrival time coherence) is desirable north of 1 kHz; his field is concert hall acoustics and psychoacoustics but I think the same psychoacoustic principles apply. I recall Earl Geddes saying that multiple sensitivities peak around 4 kHz, including sensitivity to diffraction.
And a new topic in the same pattern. I'm lost, don't kown what it is all about. What makes a speaker 'good' as a most general quest?
What this thread was about in the beginning is 'mono' evaluation at least as an additional tool.
My caveats, lacking a clear hypothesis that could possibly, as a scienticfic endevour, be scrutinized are as follows.
The 'mono' is not the intended use case. The results of 'mono' don't correlate well with stereo listening. On one hand this is the motivation of 'mono'--we see things that we won't see in 'stereo'. One might argue conversely, that the latter marks the results of 'mono' irrelevant. The concept is analytically sound but dosn't apply to the problem to be solved. (Better find a method that reveals quality paremeters when listening 'stereo'.)
The 'mono' is taken from commercial (synthetic) recordings, that are not designed to be listened to in 'mono'. This may have side effects, that are not understood. To my knowledge no investigations, neither theoretically, nor practically are undertaken to fill the gap. (Better let a sound engineer design a set of real mono recordings for this purpose, could be environmental sounds, music, speech--need to be.) The method relies heavily on the test panel knowing what a "good HiFi sound" could and should be; and there is more to it in regard to preference.
The essence of the method is the comparison of many speakers in 'mono', not just listening to one speaker alone. Additionally the audition is, of course, to be made without visual interference aka "blind". This is not available for amateurs. Hence the method cannot be replicated by the general public on a regular basis. To tell that 'mono' would be more revealing than 'stereo' even if a single speaker is evaluated alone is not supported by 'the science'.
You may see me as an 'anti' now. I'm decidedly not! I appreciate the standard that Harman introduced, even if it was commanded somehow. It was overdue for *decades*! I forgive nearly all the sloppyness in the process. But, when directly asked like in this thread, I would still be so honest to tell, mildly.
I issued my caveats many times now. No halfway sensible response, what does that tell? I'm not the engineer, and I'm happy with that.
