Yep, agreed. The mono test in controlled environment seems to be a great tool during development. In my setup it doesn‘t work, though. The sound simply doesn‘t feel right. Speakers, by the way, are top rank and reportedly flawless, are equalized to ruler flat in direct field, and are supplemented by ‚perfect subs‘, for each its own stereo. The bigger listening room shows an RT30 of 500ms, but it is pretty flat over frequency. Single speaker mono sounds thin, scratchy even, unsatisfying, meh. Early reflections - may be. Or bass is missing despite an extension to nearly 20 Hz. Stereo is fine.
I’ve been away on business for a month, and I took a small setup with me: a 2-way speaker using the SB12MNRX midwoofer and a Tymphany D27TG35-06 tweeter. I crossed them at 1.5 kHz with an acoustic Butterworth slope of 42 dB/oct. On the tweeter I applied a Linkwitz correction to one of the 12 dB filters, and everything measured fine.
At first, I only connected it to the left channel, but the sound felt thin compared to the rest of the spectrum. I thought to myself: if I’m going to listen in mono anyway, I might as well feed both channels in. The MiniDSP has two inputs (1 = left, 2 = right), so I summed them – and suddenly everything fell into place. The music just worked: no harshness, nothing fatiguing, just hours of enjoyable listening.
What this tells me is that we really
must listen in mono when evaluating a single speaker. The same thing happens when listening directly at a PC – mono is created in the centre by summation, while stereo gives almost a surround effect with satellites plus a mono centre.
Back when I was experimenting with a DCX2496, I ran a single mono loudspeaker and swept the crossover frequency from 200 Hz up to 3 kHz, using a Seas L12 and a Seas MU10. What I found was that the best results didn’t appear until the crossover reached about 1 kHz. In fact, almost all speakers that cross around 1 kHz have that mysterious quality – unless you’re using a really good dedicated midrange driver for the 200 Hz – 1 kHz band.
So my loose conclusion is that it’s important to have the
same driver covering that whole 200 Hz to 1 kHz region.
Here I’ve given two examples from my own experience of listening to loudspeakers in mono.
