Floyd Toole
Audio Luminary
Industry Insider
- Thread Starter
- #441
I am gratified that there is still opportunity for human content - this is flawed. AI will eventually "read" my 4th edition I guess and learn something.My follow up question for AI: It even came up with a recomended tracklist to use.
For most average listners making measurments is not possible if you have to bring it back to an average user who want to evelauate a speaker what do you advise.
You're right: most average users can’t make professional measurements or conduct blind tests with rotating platforms. But that doesn’t mean they can’t make trustworthy evaluations. There are simple, practical ways for a normal listener to get close to the truth about a speaker’s performance without needing lab gear.
Goal: Give the Average Listener a Reliable Way to Evaluate Speakers
Here’s what I recommend—organized into steps anyone can follow, using only common sense and basic tools.
Step-by-Step Evaluation Guide (for the Average Listener)
1. Start by Listening to Just One Speaker (Mono)
- Why: This reveals tonal balance, clarity, and any obvious flaws like boxiness, harshness, or muddiness.
- How:
- Place the speaker directly in front of you, tweeter at ear height.
- Sit at a reasonable distance (~1.5 meters).
- Play mono content (or stereo music with a strong centered vocal).
- Use tracks with clear vocals, piano, and acoustic instruments.
2. Switch to Stereo Listening in Your Room
- Set them up in a near-equilateral triangle.
- Toe-in the speakers slightly (aiming them toward your ears).
- Sit centered between them.
3. Use Familiar, Well-Recorded Tracks
Stick to music you know well and that’s well-produced. Suggestions:
- “Don’t Know Why” – Norah Jones (vocal clarity, natural tone)
- “Hotel California” – Eagles (imaging, detail)
- “Keith Don’t Go” – Nils Lofgren (live feel, transients)
- “Take Five” – Dave Brubeck (instrument placement, cymbals)
️ 4. Listen at Different Volumes
- Some speakers sound fine at low volume but fall apart when pushed.
- Others need volume to “wake up.”
5. Compare to a Reference
If possible:
- Bring in a speaker you already know (even a cheap or old one).
- A/B switching—even manually—is very revealing.
6. Minimize the Room’s Influence
If your room is very echoey:
You don’t need a treated studio—but reducing early reflections helps you hear the speaker, not the room.
- Put a rug between you and the speaker.
- Drape blankets over reflective surfaces temporarily.
- Move speakers away from walls (especially corners).
- Sit at least a meter from the rear wall.
What to Avoid
- Judging speakers solely on bass: Bigger boom doesn’t mean better.
- Being fooled by volume: Louder often sounds better—use matched volume when comparing.
- Relying on marketing claims or watt ratings: Specs rarely tell you anything about sound quality.
Final Recommendation:
If you're evaluating speakers in a store or during a home trial, ask yourself:
If a speaker passes these tests, it’s very likely a good one, even if you don't have lab measurements to back it up.
- Can I listen to just one speaker in mono first?
- Does it sound natural with vocals and acoustic instruments?
- Can I pinpoint instrument positions when switching to stereo?
- Do I feel like turning the music up—or off?
- Can I listen for an hour without fatigue?
Would you like me to create a printable version of this checklist for in-store or home use?
