thewas
- Joined
- Jan 15, 2020
- Messages
- 8,944
- Likes
- 27,777
Below video is for many an expected confirmation that equalising to some predefined curves based on some measurement rigs doesn't work well for most people due to the significant variation of individual HRTFs, especially in the lower bass and treble region, that's why also companies with large knowledge and research budget like Apple, Bose and Genelec try to compensate for those with either optical 3D scans of the ear anatomy or mic measurement inside the pad cavity. Less expected though for many (including me) is using slow sweeps to manually adjust for individual peaks after correcting the base line response based for example on such classic headphone measurements. A third interesting result is how much frequency response even dominates qualities which were usually thought be independent when equalising on the individual HRTF, like for example making an HD600 which is famous of having a narrow soundstage sounding as wide as the famous for it HD800(S).
Here is also a more detailed LMM summary of above
- (00:04–01:01) The team visits the HRTF lab at Imperial College London’s Dyson School of Engineering, where they measure Head-Related Transfer Functions (HRTF)—how each person’s body, head, and ears filter incoming sound. They insert microphones at the ear canal entrance, effectively turning their heads into measurement microphones to analyze headphones as they are actually heard.
- (01:01–02:30) Measuring headphones directly on a person’s head produces data that looks different from traditional measurement rigs (like GRAS mannequins), but it better reflects real listening because each listener’s anatomy changes how sound behaves.
- (01:50–04:42) A key experiment tested AutoEQ to the Harman target using a Sennheiser HD800S. When the EQ created from a measurement rig was applied and then measured on a real head, the frequency response deviated significantly (e.g., bass roll-off and messy treble), showing that EQ optimized for rigs does not translate reliably to individuals.
- (04:42–06:41) Listening tests confirmed this: the AutoEQ preset sounded acceptable on its own, but switching to personalized EQ based on the listener’s own head measurements revealed a much more natural sound, highlighting flaws in generic EQ profiles.
- (06:41–07:10) The takeaway: chasing perfect alignment with the Harman target curve or obsessing over measurement graphs is misguided because actual results vary greatly depending on the listener’s head and ear anatomy.
- (07:10–09:26) Another experiment EQ’d a Sennheiser HD600 to mimic an HD800S by matching their measured responses on the listener’s head. The result: the HD600 reproduced nearly the same sound characteristics (including soundstage) once the frequency responses matched.
- (09:26–10:21) This demonstrates that many perceived headphone traits (detail, soundstage, timbre) are largely tied to frequency response, though mechanical factors (clamp force, openness) still affect the overall experience.
- (10:35–11:35) Future reviews will combine traditional measurement rigs with “on-head” measurement data, allowing reviewers to show both standardized measurements and how headphones actually behave on their own heads.
- (12:02–14:00) Experiments with tone generators and diffuse-field EQ suggest that manually identifying peaks with test tones works well for correcting frequency spikes, meaning listeners can refine EQ themselves without specialized measurement equipment.
- (15:12–17:47) The video also critiques widespread reliance on Harman research and measurement targets, noting that differences in measurement rigs and human ears make it overly simplistic; the research improved headphone design but doesn’t fully capture real-world listening variability.
