A simple question: the unity gain bandwidth of the ubiquitous NE5532 is typically about 10 MHz. How much is the feedback at 20 kHz if I use it as a buffer?Stability in amplifiers is more important than large amount of feedback.
I respect the old rule to limit feedback to 36 dB in amplifier designs.
I do not have the pleasure to know Bruno Putzeys amplifiers.
Not if you ensure good phase margin with such loads. This is, of course, more difficult to do as the amount of NFB increases, but Putzeys certainly isn't advocating blind application of more and more NFB without concern for stability.Large amounts of feedback will induce stability problems especially for power amps with a complex load.
Theres so many variables that effect amp stability an "old rule" for a feedback limit dosnt make sense.Stability in amplifiers is more important than large amount of feedback.
100dB below 1kHz and from there on 24dB/decade so about about 70dB at 20kHz.A simple question: the unity gain bandwidth of the ubiquitous NE5532 is typically about 10 MHz. How much is the feedback at 20 kHz if I use it as a buffer?
Haha! Appreciate the response very much, but not quite100dB below 1kHz and from there on 24dB/decade so about about 70dB at 20kHz.![]()
I think that is good advise, use opamps with less open loop gain.Haha! Appreciate the response very much, but not quite
For the NE5322, the unity gain bandwidth is the same as the gain bandwidth product assuming it has a one-pole open loop gain curve (the TI datasheet specifies only the unity gain bandwidth and no open loop gain curve is given). For GBW = 10 Mhz, open loop gain at 20 kHz = 10 000 000 / 20 000 = 500.
For a unity gain buffer, output voltage = input voltage and therefore, for equation (2), y / x = 1, which means (1 + b A) = A. Since A = 500, 20 log(1 + b A) = 20 log(500) = 54. Therefore, we have 54 dB feedback at 20 kHz (and 74 dB at 2 kHz, etc. given the -20 dB / decade slope of the open-loop gain curve, and when frequency is above that of the pole).
So, if we go with PaulK's 36 dB rule, we surely can't use NE5322 in a buffer for audio, and we have to use opamps that have less open-loop gain! Clearly insanity!
Do you know how many NE5532 are used in devices for audio applications?I think that is good advise, use opamps with less open loop gain.
Huge open loop gain with opamps caused several cases of TIM that could have been avoided.
20 log(500) = 54
54dB, 64dB, what's an order of magnitude among friends? (edit, not quite but I like to parrot my old advisor!) The 2009 Fairchild data sheet gives a different number too.
Which depend on open loop gain and the pole locations which are decided by the many variables in an amp design. One example. If you replace the resistor in the voltage gain stage with a current source you get more gain and you can usually use more feedback.There are actually only two variables: phase margin and amount of feedback.
EE graduate courses in analogue circuit design andI wonder what experience made you challenge the 36 dB rule?
